HELP HELP
Old Dec 8, 2005 | 12:59 PM
andysrs's Avatar
andysrs
Default HELP HELP
Anyone got diamond cuts fitted, where do you get the bolts from as they got alot bigger collets on my bolts dont fit
Old Dec 8, 2005 | 06:45 PM
the benno's Avatar
the benno
repost this on gen disscusion mate
Old Dec 8, 2005 | 06:50 PM
S1 Lee's Avatar
S1 Lee
just had the same problem.
1- u can cut the end of the nuts off you get with the wheels if new, and use the collets from the nuts over your original wheel bolts. it does not effect the length of the bolt.
2- speed shack do the right bolts with the collar on that slides on. its not a fixed collar so using the 1'st method is as good. speed shack are in the back of performance ford.
Old Dec 8, 2005 | 06:55 PM
andysrs's Avatar
andysrs
Default cheers lee
i had thought of grinding the end of the nut off think thats what ill do cheers m8
