metering unit mods, any down south that can do it?
i will be needing my metering unit modded once i finish my ZVH conversion, does anyone know anywhere down south that can do the mod on it?
as close to hampshire as poss really.
cheers
cheers
Everything has its limit, but you can mod the fuel pressure as when you
chip a normal ERST, by adjusting the fuel pressure actuator, before
you then depending on what boost you are running and the AFR, then may need aditional fuelling such as a 5th, injector.
DAVE R.
DAVE R.
Originally Posted by Jano_OddKidd
IMO leave the boost around 1bar and be happy!
There is no point pushing a system so its on a knifes edge. It will bite you up the arse in the end..
Steve Escos
Oct 1, 2015 06:57 AM
