PLEASE HELP quick clifford question
what buttons do i have to press to put my car into valet mode
i need to remove the battery to do some electrcial work on the car and want to get cracking this afternoon
speedy responses appreciated, what should i expect when i have enabled valet mode? blinks, lights etc
cheers
cheers
what alarm is it?
if its G4 onwards its something you choose when you install the alarm so varies.
When in valet mode the alarm light should be on solidly on most cliffords.
Who isntalled it?
you need to ask them really.
Who isntalled it?
its a G4 500
it was in the manual but i lost it, what are the usual buttons, i know you have to press 2 but cant remember which ones
so the red led should come on solid?
Originally Posted by gingeRS
cheers
so if i press them will valet mode i can disconnect the battery?
without the alarm shitting its pants
much appreciated
rory
much appreciated
rory
cheers
have done the new earths and the car is a little happier now
the lights still flicker very lightly when the engine is running????
so far have replaced the main batt earth and engine to wing earth....anyone know where the rest are? have cleaned the earth on the windscreen wiper mount as well
where next
someone suggested it may be the diode in the alternator but would that make the batt light come on (as this doesnt happen)
cheers guys
where next
cheers guys
alternator sounds a good place to look mate, as it sounds like the voltage isnt stable with the alternator running
or just check connections
dont wanna have to put another one on????
SMILER258
Sep 28, 2015 09:04 AM
