General Car Related Discussion.To discuss anything that is related to cars and automotive technology that doesnt naturally fit into another forum catagory.
def look good anthracite but be careful taking them apart, think they might be pressed together as well as bolted. My mate took out all the bolts on his RX7 wheels but couldn't get them apart.
a lot of them arent actually split rims just fake bolts. also if they are split they will be out of balance when you take them apart an put back together
They were def split rims, a company took them apart for him and polished the rim for him and i painted the centre's black. They looked the bollocks when they were back on the car
@ justin.e these wheels are more expensive than all the wheels on your cars, and i wasnt the one who keptbraking down at mondello! nothing wrong with my car i drove it home and i did all the work on engine [/quote]
its not my fault power steering pipes are shonky see ya on track in Jan then???on a serious note Ted buy some proper wheels and keep the bling for shows
how about the centre the same colour as ur car? might sound a bit crap,BUT.. ive seen it on a e30 widearch m3 that looked AWESOME!same colour as urs too!
right first thing, they are split rims but you carnt take them apart because they are welded all around the two bits, so you will have to get them painted as they are.
Yours do look but i do like mine better and yes you did have your first but mine took about a year to get
Mine look quite bad at mo duncan went into gravel trap last time out and stones chipped the stainless rim on the two wheels passenger side ,
Yours do look quite nice in that colour and are probably easy to keep. I might have to , as justin says buy a set of leggras for track days!
