cosworth rear diff option
cosworth rear diff are no good i can only wheel spin or brodside 1 side to my left is ther a clutch in the diff as it seems that 1 wheel doesnt do as much as the other .was told that the quaife is a gear operated so no plates to break or wear is this true
Originally Posted by Kevin Sharp
you will be using a tired 19 year old diff then with the VC in dire need of pumping up...
the viscous unit in the diffs are usually tired on old high mileage units so making them have very little lsd action, they need stripped and rebuilt by a specialist.
jessie_rs
11
Jun 3, 2019 04:57 PM
155lee
Sep 14, 2015 07:37 PM
Aug 14, 2015 07:29 AM
xr4x4rs
Aug 6, 2015 09:03 PM
