just got a zvh engine just wanted to no a few things were is the oil cooler on the zetec block if there is one . is the plate that goes between the gear box and the engine the same as the normal cvh is ther any thing else i need to buy to do the conversion and were do i get the bits from cheers in advance .
DONT HAVE OIL COOLER U NEED A ESCORT ZETEC OIL PUMP THE 1 THAT THE OIL FILTER SCREWS ON TO JUST BOUGHT 1 FROM FORD 250 NOTES WOULDNT BOTHER WITH A DECOMP PLATE,GET YA SELF A SET OF FORGED ACCRILITE PISTON FROM BURTON POWER 400NOTES I JUST GOT SUM MELTED STANDARD 1S
