Standard T3 turbo
Old Dec 2, 2005 | 09:55 AM
T28 RST's Avatar
T28 RST
Ok then
Default Standard T3 turbo
What power will it handle
Old Dec 2, 2005 | 10:55 AM
SamERST's Avatar
SamERST
My guess is a little over 200bhp obvously you could get more but it aint gunna last.
Old Dec 2, 2005 | 10:56 AM
Charlie Chalk's Avatar
Charlie Chalk
Unknown.
LOL.....
Check Jamsports/PF Mags car
Old Dec 2, 2005 | 11:03 AM
SamERST's Avatar
SamERST
huh ?
DavesRsTurbo's Avatar
DavesRsTurbo
What PSI would it reech and not die in like a month lol
David
Old Dec 2, 2005 | 11:09 AM
SamERST's Avatar
SamERST
well my mates running 18psi switchible and is pushing just under 200bhp his been alright so far (about 4months)
Old Dec 2, 2005 | 11:12 AM
Charlie Chalk
Unknown.
I ran 18psi on my standard turbo with no issues
Old Dec 2, 2005 | 11:16 AM
DavesRsTurbo
If i got a chip
nice intercooler
-31 actuator
And tuned
Ive already got Full scopion Exhaust sytem
K&N
Full Samco Hoses.
Just new cambelt and tappets well silent now
What you lot recon my Bhp Will be
David
Old Dec 2, 2005 | 11:22 AM
SamERST's Avatar
SamERST
I know ill get flammed for this but thats basicly the spec my mates running in his van and his seeing just under 200 brake with 18psi. It all depends on the engine mate the mfi cvh aint as bad a engine as most people like to make out you can still see decent power with em.
Old Dec 2, 2005 | 11:26 AM
T28 RST's Avatar
T28 RST
Ok then
here is your answer
https://passionford.com/forum/viewtopic.php?t=159161
Old Dec 2, 2005 | 02:22 PM
vroooom ptssssh's Avatar
vroooom ptssssh
It Wasnt Me!
DavesRsTurbo, get the K&N OFF an std airbox with panel filter ON and cut the front off it to open it up (where the circular hole is)
and if it's the old style scorpion, swap the backbox to mongoose or magnex, as the old tyle scorpion is restrictive (2.5" (std diameter) all the way through to the backbox, then 2" In the backbox (smaller than std diameter). That will be a better basis for more power.
Old Dec 2, 2005 | 10:55 PM
AKRS1's Avatar
AKRS1
18psi is probably max setting for standard turbo but better to run a 2 stage boost control
Old Dec 3, 2005 | 12:29 PM
DannyDK's Avatar
DannyDK
How much increase of power will there be if i removed my KN Cone filter and fittet the filterbox with the original filter and make the hole that you are talking about? What does the Cone filter give then if not HP, torque and how much?
Matt Baxter
Sep 16, 2015 08:30 PM
gchristophi
Aug 31, 2015 10:36 PM
muz
Aug 16, 2015 12:57 PM
A.t.p
Aug 15, 2015 11:37 AM
mpilk
Aug 12, 2015 09:40 PM
