Suspension....again
Old Dec 1, 2005 | 01:38 PM
adamS2RST's Avatar
adamS2RST
Default Suspension....again
I know there are a few threads kicking about in here...I'm thinking of buying a set of second hand Koni's off cossiecrew. What are peoples view's on Koni's? I know Spax are supposed to be quite a harsh ride....I just can't justify coilovers at the moment.
Old Dec 1, 2005 | 02:36 PM
Taylor's Avatar
Taylor
Have a set of koni adjustable top mounts on mine,have had it 6 and a half years now and no probs,have found the ride ok
Old Dec 1, 2005 | 04:07 PM
adamS2RST's Avatar
adamS2RST
Oh, and can I use any springs with them? I don't want to go lower than 25mm.
Old Dec 1, 2005 | 05:14 PM
Ad4m RST's Avatar
Ad4m RST
Jiu Boxu
koni best bet for a RST i rekon, without stretching to coilovers like you say
Old Dec 1, 2005 | 05:25 PM
Micky's Avatar
Micky
I use Koni top adjustable's,never had a prob with them.Use Chassis Dynamic's springs which are -25mm lower.Great combination!! Regards Micky
Old Dec 1, 2005 | 05:45 PM
PaulT's Avatar
PaulT
I am the opposite having just removed Konis from my series1 and put on a Spax psx kit, will agree its a lot firmer even on the lowest damper setting(1 of 28), but in all fairness the Konis were not in good shape with 2 of the 4 leaking slightly still not bad for 8 year old suspension though. I am doing Donington on Saturday so will let you know how the new stuff performs.
PaulT
Old Dec 1, 2005 | 05:47 PM
JesseT's Avatar
JesseT
I've seen quite a few Spax for RSTs with rusty rods and bent tubes. Nothing such with Konis.
Old Dec 1, 2005 | 06:03 PM
adamS2RST's Avatar
adamS2RST
PaulT
8 Years, that's fairly good going if you use it on track too! My last suspension kit lasted under a year and about 3K miles
Cheers for the input peeps
Old Dec 1, 2005 | 06:05 PM
Oranoco's Avatar
Oranoco
Got an old Spax Sport kit on my RST and it's been good for about 5 years now. When the eventually give up the ghost I will probably fitting Koni T/A's as the car is spending more time on track now
Old Dec 1, 2005 | 06:12 PM
Taylor's Avatar
Taylor
Had my koni's 6 and a half years now and not had any probs,they were already on the car aswell but not sure for how long
Old Dec 1, 2005 | 07:04 PM
Andy-R's Avatar
Andy-R
Cant fault Konis
Ive got a set of Spax adjustables on my 306 I rate them highly, only issue I have with them is that they arent top adjustable they are adjusted by a screw at the bottom, this is prone to rust and broke withing 12months.
Are spax top adjustable for the S2?
I guess the next consideration is then spring rate and height.
Old Dec 1, 2005 | 07:24 PM
Charlie Chalk's Avatar
Charlie Chalk
Unknown.
Been in a few S2's and had an S1 with konis
Cant fault them
Old Dec 1, 2005 | 09:22 PM
James Raby's Avatar
James Raby
Just get a decent spring to go with them
Eibach or Cobra
Old Dec 1, 2005 | 09:24 PM
DanRSturbo's Avatar
DanRSturbo
I bought a spax kit off e-bay for Ł120, 6 months old, no problems whatsoever, solid as a rock
Old Dec 2, 2005 | 06:48 PM
kiddie's Avatar
kiddie
had koni t/a on both my S2's and they are
Old Dec 2, 2005 | 10:50 PM
AKRS1's Avatar
AKRS1
i have konis top adjustables with eibach springs ride height is perfect and so is the drive
Old Dec 3, 2005 | 09:10 AM
adamS2RST's Avatar
adamS2RST
Best sort some Koni's then I guess
Old Dec 3, 2005 | 01:06 PM
andre_k's Avatar
andre_k
IMO my g-max kit is well harsh. are the konis better?
Old Dec 3, 2005 | 03:02 PM
John Laverick's Avatar
John Laverick
I have Spax top adjustables and Chassis Dynamic Springs....I have then set on softest setting and they are quite crashy over bumps. Not had any problems with them in 4 years though!!
