pinking in every gear
Old Nov 30, 2005 | 06:47 AM
JayRS2000's Avatar
JayRS2000
Default pinking in every gear
my cars badly pinking sounds like two metal things bangein hard as fook what can i do it stop this as its doing my head in and ive bin told its very bad too
Old Nov 30, 2005 | 07:26 AM
twinkle_2k86's Avatar
twinkle_2k86
go get it set up ASAP. or you will be having a very expensive repair on your hands.
Old Nov 30, 2005 | 09:05 AM
GrimmeRS2K's Avatar
GrimmeRS2K
sounds like the ingition timing is out.
Old Nov 30, 2005 | 10:01 AM
adamS2RST's Avatar
adamS2RST
I'd take your car in somewhere mate, it seems your posting on here every day with a new problem!
Old Nov 30, 2005 | 11:02 AM
Ad4m RST's Avatar
Ad4m RST
Jiu Boxu
you're gonna have to bite the bullet on this one mate, get it setup or you gonna have a dead car....
Old Nov 30, 2005 | 11:47 AM
Oranoco's Avatar
Oranoco
Banging doesn't side like pinking.
Pinking is more of a metallic tinkling. Get it looked at asap or things may get expensive.
Old Nov 30, 2005 | 02:00 PM
SafeChav's Avatar
SafeChav
OMG
Pinking aswell
mate seriously i'd be stripping the engine down and starting fresh
as for the guy that sold it you
Old Nov 30, 2005 | 02:20 PM
sufsRS's Avatar
sufsRS
hi again you really need to take it to somewhere reputable and get everything seen to make sure you have your wallet
Old Nov 30, 2005 | 10:08 PM
JayRS2000's Avatar
JayRS2000
im running it on superunleaded does that help it tall ?
Old Nov 30, 2005 | 10:13 PM
SafeChav's Avatar
SafeChav
should be harder to make it pink if your running it on super unleaded
Mate sounds like theres summit seriosuly up.
Have you checked the timing, you might cure the revving and pinking problem in one hit with that, so much so it might be driveable to a tuning garage.
Old Nov 30, 2005 | 10:49 PM
yzfr1boy's Avatar
yzfr1boy
hi i tried everything on my mates car timing mixture dizzy all to noavail then swapped ecu for mine then it was fixed got another off e bay never pinked since hope this helps maybee try 1 of somone local you can swap with for five mins
Old Dec 1, 2005 | 01:32 PM
andre_k's Avatar
andre_k
dont be tight... TAKE IT TO A SPECIALIST!!!!!!!!!!!!!
or your engine WILL die
trust me, a trip to jamsport or somewhere similar, a setup + check-over, replace dodgy parts, and youll be driving home with a BIG grin
Old Dec 1, 2005 | 01:40 PM
ASHCOSSIE's Avatar
ASHCOSSIE
check your tps as if this is not working that will make it pink i had that
Old Dec 1, 2005 | 04:18 PM
Oranoco's Avatar
Oranoco
MAP sensor in the ERST ECU can go tits up and casue these symptoms. If Jamsport are local to you then call in there. Good bunch of lads
Old Dec 1, 2005 | 05:31 PM
Taylor's Avatar
Taylor
Get it to a tuner asap mate and you will know the score after that
Old Dec 2, 2005 | 10:18 AM
JayRS2000's Avatar
JayRS2000
well im hopefully getting the timing seen to on thursday and ill have my new cam tappets cambelt oil and filters fitted and then ill try and find a descent local tuner to set it up fingers crossed i dont wanna be lookin for a new engine just before xmas!!!!!
im just driving back and forth to work and not boosting it at all hopefully by not boosting it will do less damage i hope
tankybaby66
Feb 6, 2016 02:24 PM
The Youth.
Sep 30, 2015 09:59 PM
dojj
Sep 29, 2015 10:32 PM
cameron2
Sep 23, 2015 06:31 PM
