Standard Gearbox...?
Old Nov 29, 2005 | 10:15 PM
dave_y's Avatar
dave_y
Default Standard Gearbox...?
just a quick question. what is the standard gearbox upto power wise?
ive just had my car chipped and its still on the standard gearbox.
if its likely to die then i would rather replace is sooner rather than later.
im running 175bhp 191lb/ft.
also what about the standard clutch? i think it may have started slipping recently but i can't really comfirm that until i fix the leaking oil from my rocker cover...
thanks!
Old Nov 29, 2005 | 11:26 PM
mine was on standard box and clutch for a few yrs at 197bhp... was fine. then the box blew and i bought to many shitty 2nd hand ones (bad choice). tbh its worth considering a bernie box if ya can or a refurb from fords. but saying that this standard box touch wood is still ok 6mths on and i have an organic clutch
Old Nov 30, 2005 | 03:34 AM
DannyDK's Avatar
DannyDK
Whats a bernie box?
Old Nov 30, 2005 | 05:45 AM
Poom's Avatar
Poom
A box from www.gearboxman.co.uk I think
Old Nov 30, 2005 | 11:25 AM
Old Nov 30, 2005 | 11:45 AM
Oranoco's Avatar
Oranoco
Depends how hard the car is driven?
Eventually it's bound to break. Wouldn't have thought it will be too bad for exploding at that power level. If it does go bang get one of Bernie's gearboxes
Old Nov 30, 2005 | 07:02 PM
dave_y's Avatar
dave_y
car isn't driven too hard.
will have to see when i next drive it. like i said i could have got some oil on it causing it to slip cause it wasn't slipping on the rollers or on the drive home.
Old Nov 30, 2005 | 10:53 PM
david's Avatar
david
Ive killed boxes with just over STD power in the car, all down to how its driven really
Old Dec 1, 2005 | 03:18 AM
Combi_Chris's Avatar
Combi_Chris
just get a bernie box and then you CAN drive it hard !!
Old Dec 1, 2005 | 07:09 PM
Andy-R's Avatar
Andy-R
Buy a Quaiffe Diff shove that in and bingo nae problems.
Old Dec 1, 2005 | 07:27 PM
Oranoco's Avatar
Oranoco
I beleive with the RST box it's usually the layshaft and/or it's bearing that fail.
Old Dec 1, 2005 | 07:30 PM
Charlie Chalk's Avatar
Charlie Chalk
Unknown.
Like a usless c'unt then
Old Dec 1, 2005 | 07:40 PM
Oranoco's Avatar
Oranoco
Recon boxes vary dramaticaly. I wiped one out in 7 hours and the company refused to sort it as the car was modded. Shortly after the next box went in it was sent to a rolling road road where it made 119bhp
Wankers
Old Dec 3, 2005 | 12:20 PM
DannyDK's Avatar
DannyDK
So to deal with that problem is to fit bigger bearings right?
What is the layshaft and where is it located in the box, is there a better one you can fit?
Old Dec 3, 2005 | 03:17 PM
JesseT's Avatar
JesseT
Nothing wrong with the shaft, but the bearing at the end of it should be uprated. The IB5 bearing can be installed with minimal machining to the casing.
XR4
Ford XR Range
Oct 1, 2015 12:46 PM
PRO-LINE MOTORSPORT
Sep 28, 2015 09:54 PM
SMILER258
Sep 28, 2015 09:04 AM
