4x4 saph coolant and anc samco hoses
im finally getting round to fitting mine soon and was just wondering how hard is it to change the ancillary hoses ?
any tips or help for when i do them ie whats best to change first etc etc
cheers guys................matt
Hi, judging by your login name i presume you haven't done them yet so.........
1)Make sure the engine is cold
2)The clips on the hoses going into and out of the oil cooler can be hard to tighten if you still have the leads on the dizzy cap. I found it easier to remove them first.
Hope it helps
Dave
Hope it helps
Dave
Russ Payne
Sep 25, 2015 08:29 PM
