escort reshell??? info!!!
Old Nov 28, 2005 | 06:56 PM
ital_cossie's Avatar
ital_cossie
Default escort reshell??? info!!!
hello,
i found a ford escort rs cosworth damaged and i would like to know which shell can i use from another escort i don't know 1.6 , 1.4 CL , GLX???? which??? so i can transfer all the parts and build an escort from 0.
waiting your answer and links if possible or a site with someone who has done it yet.
thanx
Old Nov 28, 2005 | 07:23 PM
Speedy G.'s Avatar
Speedy G.
If you want to genuinly keep it as an Escort Cosworth, then you can only use an Escort Cosworth shell m8.
Normal Escorts are TOTALLY different.
Old Nov 28, 2005 | 09:23 PM
DazC's Avatar
DazC
As above. The Escort Cosworth shell is a shell of it's own. Not the same as any other Escort shell. Even the wheel base is different if I recall correctly.
Old Dec 2, 2005 | 11:32 PM
PaulCossie's Avatar
PaulCossie
you could convert a std shell but it would mean grafting transmission tunnel, suspension mounts... and all the other things etc etc, way too much work if you ask me!
just as a note the escos shell is 4" longer than a std escort shell...
Old Dec 3, 2005 | 02:10 PM
Nick C's Avatar
Nick C
You would need another Cosworth shell mate, get some pics up of it - never know it could be repairable
Vincereese
Jun 1, 2023 09:14 AM
FlashRS
Sep 14, 2015 12:36 PM
Bighandsuk
Sep 2, 2015 05:23 PM
Vincereese
Aug 18, 2015 03:57 PM
Vincereese
Aug 16, 2015 06:38 PM
