preserving paint
i put my car away for the winter at the start of last week,i washed and polished it befor i put her to bed,is there anything more i need to do or will she be ok til mid april??ps handbrakes off and windows are 1/4 inch down
covers are ok as long as the garage isnt damp at all, otherwise they tend to make the car sweat and you can get condensation underneth them if stored for a long time., cotton sheets are better cus the car can breathe through them
other than that thats pretty much all you can do. if being stored for years then there are other things you have to worry about.
hope this helps, cheers mark.
cheers mark,just one more Q,when its finally time to bring her out again is there anything to check especially.eg perished rubbers,fuel lines etc from not being in a heated garage
i wouldent have thought so as its only gonna be for 6 months, just check all the levels and crank the engine over a few times to bring the oil pressure up before actually starting it. oh also might wanna put some new fresh petrol in it when you come to start it to cus that will help.
cheers mark.
cheers mark.
well if its sittin on the wheels for a long time the tyres are taking the weight of the car on one point, they can crack and perish or even go flat if left on its wheels for years. plus it takes a lot of the stress off the suspension.
Putting the car on axle stands is a complete waste of time in my opinion. I've been storing my XR2 every winter for 10 years now. I fit a set of old steel rims with old tyres and pump them up to about 40 psi.
The suspension is not under any unusual stress in this state. Put it on axle stands though and the dampers will sit on maximum stretch fo a long time.Definately not a natural suspension position.
Theres also a small matter of mobility, OK a thief might not move a car on axle stands easily, but neither can you. What would happen in the horrendous case of a fire etc where you could move the car to safey on wheels,but just watch it cook on stands.
Cheers Stuart
Cheers Stuart
Cheers Stuart
Cheers Stuart
id rather have the car in the air with no weight on the suspension than having all the weight of the car sitting on all the suspension components
you say what would happen in the case of fire, ask yourself this, what would happen if the garage flooded, would you be happy to know your car is sitting in 2 foot of water or would you be even happier still in knowing its out of harms way on stands. plus you have just admited its better protection for your car if some toe rag of a thief does break in.
cheers mark.
now im worried about fire and thiefs
, i've got a council garage but only the mrs knows where it is,and i made sure nobody was about when i parked/hibernated her,so i suppose it would be down to bad luck if they popped my garage instead of one of the other 20,will prob leave on steel wheels,just so i can wheel her out to clean once every 6 weeks,roll on the first nice week in april
,boring now as im driving a escort 1.6 on a k-plate(ghia)
,but at least its got leccy windows the heaters are shit-hot and i get 80-90 miles to a tenner instead of 30-35 in the saph
never mind only just over 100days to go till she un-hibernates
i would put it on axle stands but support the suspension with blocks of wood in the half way position..
[img]
Try getting a two storey garage if at all possible floods suck and it was on wheels but the water only took an hour and half to rise. Before i knew it i was waist high in Portsmouths finest .[/img]
Originally Posted by m4dyeti
[img]
shit bad luck m8!
Don't ask - I don't know
The suspension is not under any unusual stress in this state. Put it on axle stands though and the dampers will sit on maximum stretch fo a long time. Definately not a natural suspension position.
Cheers Stuart
Cheers Stuart
Been storing my S1 over the winter for 10 years mate and that's what i do.
rsguy
44
Sep 29, 2015 03:29 PM
