FAO Welders! Price (ish) needed! Battery tray mk4 escort! :)
Hi Guys,
How much am I looking to pay to get it fitted? Finding it hard to get quotes as I cannot take the car to bodyshops and not many are willing to come have a look at it
Once I have found somebody who can do it on my drive or will give me a price I will have to trailer it to them!
seen some F/G reg cars with wax backed sound proofing and they are worse to weld. Found I had to pull the dash out or it was a fire hazard.
Earlier ones are not as much of a problem.
Price would depend on if you wanted it 'just welded' or you expect it to be 'restored'
Big difference.
And £100 sounds cheap.
Big difference.
i payed 60 quid for one years ago and the burn all the wax backing you mention
100 quid is the norm mate, restoring and removing the old one nd fitting a replacement pannel are the same surely
you aint gonna lead load the batt tray are ya
weld, seal and repaint, its just to hold the battery after all
proper
please discribe whats proper about a bat tray
tell me whats soo different that it takes 285 quid in labour as the replacment panel is about 15 quid
how many hours it take to be done proper then ????
now dont get me wrong as a bad job WILL leak like a fooker and thats bad but the replacement pannels are ok tbh and mine was spot on apart from the burnt sound deading
for 60 quid they prob ujst ground the old "tray" off then just welded the new section with tray attatched over the top...
having it done properly would involve cutting all the old shit out, replacing any bits of the bulihead which have also gone aswell as the inner wing, so you have something to weld to, weld the new unit in, grinding all welds smooth, filling joins and paintng underneath aswell as above...
See Tonys thread near the beginning to see what I mean.. look in his bay and there is NO WAY of telling its EVER had a tray... though I put on the third of its life
mine wasa good job and it wasnt just gound off either as the back of the bat tray was totally fooked, but i may have been lucky supose
the batt tray on my tennis was replaced and i had no way of telling,,,,,,,,,, WELL apart from when i cleaned the bay wioth thinners and noticed they matched the paint to the dirty white that the bay was paintied, now i got a dirty white paint and the rest of the bay it super clean white
heres a strange thing though, the 2 orions ive got and my escort cabrio that i use has never had a batt tray and they aint rusy either
why could that be
why could that be
somebody needs to learn how to weld
to do a batt tray properly like moose said £400
that includes droping dash
cutting out out tray n metal welding it in
linishing it
filing it
priming it
painting it
and if you add it up thats cheap really
2 day job
workshop needs £80 a day to keep running
working for £100 a day
leaves £40 for materails
i would weld one in for £120 cash with no painting or welding inside
linishing it
filing it
priming it
painting it
2 day job
Thats mine
I have the panel! I am planning to prime and paint it myself so I will be able to prep it also! I just need the actual welding doing and I can do the cosmetic side of it
Originally Posted by b19bal
thats erm,,,,,,,,,,, interesting
That is all I have managed to find....so far!
I can do most of it myself like remove the dash, prep and paint it!
I just basicly need the panel cutting out, new one welding in and then the welds tidied so I can smooth, primer and paint the bay
I will supply this
also
I will supply this
There are no other spots I can see (There is only the fusebox and gearbox left in the engine bay and no carpet inside)
Then there is a slight buddle on roof and inside the boot it has been abused but I have temp fixed that for now!
Originally Posted by xr4x4rs
nick now looking at that pic
dash does need to come out
also the heater as well bu the looks of things
then all the sound proofing
has ray not got back to you?
nick mate id take neil up on that offer , saves you them money of tralering it to people for a quote, cus he has already seen how bad it is lol
good luck dude
good luck dude
track.focus'd
Aug 12, 2015 05:53 PM
