Heat shield
Old Nov 26, 2005 | 10:24 PM
RST Ski's Avatar
RST Ski
Default Heat shield
any1 no where i can get a starter motor heat shield (mayb chrome) for my d reg erst? my wont start when hot! [img][/img]
Old Nov 26, 2005 | 10:39 PM
Ad4m RST's Avatar
Ad4m RST
Jiu Boxu
why not wrap the downpipe, turbo in heatwrap
Old Nov 26, 2005 | 10:57 PM
RST Ski's Avatar
RST Ski
think i will, the actual sheild is missing, will the wrap be enough? ive only just bought the car, the helmet b4 shoved this silver crap in between the starter n down pipe!
Old Nov 27, 2005 | 10:57 AM
addiction's Avatar
addiction
you can still get the heat shield from Ford
Old Nov 27, 2005 | 11:20 AM
RST Ski's Avatar
RST Ski
yeh think il order 1 in
Old Nov 27, 2005 | 06:11 PM
T28 RST's Avatar
T28 RST
Ok then
Lag the down pipe and get a heat blanket for the starter, thats what i did and its been fine for years
Old Nov 27, 2005 | 09:47 PM
1.9 xr2 on 40's's Avatar
1.9 xr2 on 40's
st170 breaking
check the starter cables too, if they are burnt up (ive had a few where black was tourched from bein fitted dodgly)
if they are damaged then heat affects them dramatically too
had same problem as you, fitted another neg starter cable over top of old 1 and never had problem again
Old Nov 27, 2005 | 10:02 PM
Rallyesport's Avatar
Rallyesport
Wraping the turbo is not a good idea. It will get too hot for comfort. You can wrap the manifold, downpipe, and the section of the exhaust that rund under the engine. Heat is a big issue with this car. "Hey, let's give it some more power and shrink the radiator!"
Old Nov 28, 2005 | 04:54 PM
Tony Turbo's Avatar
Tony Turbo
www.ctuceilings.co.uk
Took the words right out of my keyboard
Old Nov 28, 2005 | 05:05 PM
Oranoco's Avatar
Oranoco
Wrap the starter if you want to wrap anything. Might be worth wrapping the downpipe as well but leave the turbo alone
Ford Focus RS Parts for Sale.
Mar 9, 2016 01:03 PM
Nov 5, 2015 08:12 PM
cossie09
Sep 10, 2015 06:56 PM
