pros and cons of a dogbox
Old Nov 26, 2005 | 12:23 PM
creedy's Avatar
creedy
Default pros and cons of a dogbox
as title says?
looking at getting sum short of uprated gearbox for my pulsar (yes i knw its not a ford) but this is the fountain of all knowledge
as some of you mite knw the pulsar box keeps breaking the end casing apart with high power, due to the helical cut gears. so im thinking the straigh cuts gears will stop this.
but chip said they will need rebuilding about 20k miles. so if anyone has any experance with dogbox's please share. what they like to live with?
creedy
P.S. the dogbox kit is a PPG kit from oz
Old Nov 26, 2005 | 01:42 PM
Fiecos Dan's Avatar
Fiecos Dan
Pro's
faster and clutch free gear change, so also stops the chance of slippin clutch on gear change,
normally stronger, and take more power due to straight cut gears
Con's
rebuildin cost are high as need to be rebuilt more often,
harder to drive, can be a night mare round town,
their usually louder, due to normally bein straight cut gears.
Old Nov 26, 2005 | 01:56 PM
Sexy-RS's Avatar
Sexy-RS
I used to have a dog box in my bmw, reverse was where 1st was and 1st where 2nd should be!
Was a nightmare using that and my fiesta I kept getting them muddled would go to pull away in 2nd every time i got back in my Fez
Old Nov 26, 2005 | 02:00 PM
Billabong's Avatar
Billabong
That's a dog-leg first, not a dog engaged 'box.
Old Nov 26, 2005 | 02:10 PM
Sexy-RS's Avatar
Sexy-RS
Oh thats what it was whoops
Old Nov 26, 2005 | 02:21 PM
Ginge !'s Avatar
Ginge !
just finding my feet
i had someone tell me the exact same thing once
Old Nov 26, 2005 | 03:58 PM
creedy's Avatar
creedy
Old Nov 26, 2005 | 04:09 PM
gearboxman's Avatar
gearboxman
I believe you can get a stronger sandwich plate on its own.
Either PPG or Giken, forget which.
Dog boxes on the road are just hopeless...
Old Nov 26, 2005 | 04:15 PM
markk's Avatar
markk
mine is no problem to live with, certainly no harder to drive with than any other box, noisey - yes rebuilds well , i suppose this is to be expected , after all it is for competition use, for the road - forget it , wont last you 5k
Old Nov 26, 2005 | 04:33 PM
timrud's Avatar
timrud
Can't you just get a normal straight cut box rather than a full on dog box?
Bit of a compromise?
PRO-LINE MOTORSPORT
Sep 28, 2015 09:54 PM
