Heat sheilds(S2)
Old Jul 10, 2004 | 10:12 PM
Stoo's Avatar
Stoo
Default Heat sheilds(S2)
What do you all think of stainless steel heat sheilds?
I have one but i havent put it back on since i fitted the GRS,i feel its going to stop the heat from escaping through the vents properly and keep too much heat floating around the back of the radiator...? This being a bad thing,but then why is it called a heat sheild?Whats it sheilding the heat from?The spark plugs?
Old Jul 10, 2004 | 10:19 PM
McPikie's Avatar
McPikie
Its stopping up from rising up to the inlet charge carrier.................
Although I dont see why ford attached it to the cam cover, had they never thought of heatsoak from there???
Old Jul 10, 2004 | 10:21 PM
KSA-Cossie's Avatar
KSA-Cossie
I got one with small vents in it,think it's meant to shield heat from your charge carrier on top of the engine.
Old Jul 10, 2004 | 10:27 PM
Stoo's Avatar
Stoo
Cant see a prob with putting it back on then
Cheers lads Oh and ksa74f/231bhp i sent that cheque off this morning for you!
Ford Focus RS Parts for Sale.
Mar 9, 2016 01:03 PM
Nov 5, 2015 08:12 PM
cossie09
Sep 10, 2015 06:56 PM
