Any way to mod your lsd or make it stronger? Options
Old Nov 23, 2005 | 04:17 AM
DannyDK's Avatar
DannyDK
Default Any way to mod your lsd or make it stronger? Options
Im goin to rebuild my gearbox now that i have to fit a new clutch and such anyway, so i would very much like to know if there is a way of making the LSD stronger so it dont break when you accelerate(with, unfortunetly a bit of spin). I know that my ERST isnt the strongest around but it has 170bhp and 263nm, but im aming for 200bhp and 300nm or so and then the LSD will fail im told, and i would like to keep the gearbox on and not have to take it out now and then to fit a new(used)LSD just because i want a litle more fun with my funny(very funny indeed)car.
Old Nov 23, 2005 | 11:32 PM
check out this months Fast Ford mag (chip's custard 3dr on the front) its got all about LSD's in it page 148
or give gearboxman a shout
Old Nov 23, 2005 | 11:36 PM
NUTS RuS's Avatar
NUTS RuS
Change the fluid inside it for a more viscous one.
Old Nov 24, 2005 | 04:58 AM
DannyDK's Avatar
DannyDK
what do you use for your own gearbox and what should i use to make it stronger?
Old Nov 24, 2005 | 06:37 AM
NUTS RuS's Avatar
NUTS RuS
DannyDK - I have the full Quaife straight cut close ratio box, it gets looked after and rebuilt several times a year by either myself, or Bernie at CTS
Old Nov 24, 2005 | 02:51 PM
DannyDK's Avatar
DannyDK
Is the used parts form your box any worth?
Old Nov 24, 2005 | 06:54 PM
NUTS RuS's Avatar
NUTS RuS
No but I sometimes use them as paperweights at work.
Old Sep 18, 2006 | 06:58 AM
Rallyesport's Avatar
Rallyesport
Where can I get new or better fluid for my LSD and is it possible to get new plates in the diff? I rebuilding the box this winter and I want to rebuild the diff aswell.
Old Sep 18, 2006 | 07:35 AM
addiction's Avatar
addiction
Default Re: Any way to mod your lsd or make it stronger? Options
who told you that?
Old Sep 18, 2006 | 08:17 PM
Rallyesport
Anyone rebuilt their lsd?
Old Sep 18, 2006 | 09:08 PM
NUTS RuS's Avatar
NUTS RuS
Never bothered changing the plates in mine, I took one to bits once, that was enough, looks impossible unless your very patient.
Fluid usually gets done once a year, either local or at CTS (gearboxman in UK)
Old Sep 19, 2006 | 05:32 PM
Rallyesport
Have you changed the fluid yourself? Where can I buy the fluid? When you diff is sent to CTS, have they ever changed the plates or is it not necessary?
Old Sep 19, 2006 | 08:22 PM
NUTS RuS's Avatar
NUTS RuS
Never found it necessary to be honest.
If you want a different (better) diff choose a different manufacturer.
Do you know how the fluid is held in and whats involved in changing it ?
Old Sep 20, 2006 | 05:42 PM
Rallyesport
I'm rebulding my box and want to investigate how to rebuild the diff aswell. A new diff at the cost of 500 pounds is out of the question.
This is the viscous lsd unit.
Some guys I've talked to that have rebuilt their Cosworth lsd unit bought the fluid at Ford. I've also talked to CTS about buying fluid, but since they have spent money on developing the fluid, the wouldn't sell it.
Old Sep 20, 2006 | 07:09 PM
NUTS RuS's Avatar
NUTS RuS
Default Diff Oil
Is the ball bearing still in place in the case ?
Old Sep 20, 2006 | 07:18 PM
Rallyesport
I haven't taken my box apart yet.
Old Sep 20, 2006 | 11:03 PM
NEWTON's Avatar
NEWTON
ive rebuilt my box i took my lsd to a place in bromsgrove called bara motorsport had it rebuilt and modified,he changed the fulid to a different viscousity and that worked wonders it tighted it to 120nm,very tight diff ill get the number up for you
Old Sep 20, 2006 | 11:16 PM
NUTS RuS's Avatar
NUTS RuS
I have already sent it to him yesterday matey
Got to bear in mind he's from abroad and posting diffs to the UK will be expensive
Old Sep 21, 2006 | 05:44 AM
Rallyesport
How much did you pay? All they did to tighten it was to change the fluid?
Old Sep 21, 2006 | 01:44 PM
Rallyesport
Talked to DOME, and nobody will sell the fluid seperatly.
Old Sep 21, 2006 | 04:48 PM
NUTS RuS's Avatar
NUTS RuS
... and your next option is ?
Old Sep 22, 2006 | 01:37 AM
NEWTON's Avatar
NEWTON
it had the fluid changed and was rebuilt use new parts,the cost was 300.00 quid
Old Sep 22, 2006 | 01:40 AM
NEWTON's Avatar
NEWTON
had the same problem,no one will sell it
Old Sep 22, 2006 | 03:14 PM
Rallyesport
I will have to search further for this fluid. Everthing I do on the car is DIY.
jonfoc
16
Sep 11, 2018 05:35 PM
BIL N KEL
Nov 29, 2015 03:36 PM
hopper350
Sep 4, 2015 12:53 AM
cossirob
Sep 3, 2015 09:17 PM
