Peeps wiv 4pots on S1 & S2.
Right i am all ready to mount them on, its just on the pictures i have i can't tell which side the caliper should be mounted???
Is it this side?
Or this side?
Because i aint got me offset bells and rotors yet i am unsure, I know the bleed nipples have to be at the top.
Is it this side?
Or this side?
Originally Posted by Moose 130
pretty sure it was as per pic2 but you have to remove 4mm from the caliper mounting surface to make them fit.
Daz u twonk................... use your mince pies
Originally Posted by DazC
Surely any normal person would have sat the disc on and offered the caliper onto the disc to see where it went?
Originally Posted by Billy Cabrio
Because i aint got me offset bells and rotors yet i am unsure.
I hope you got some serious clearence on the back of the wheels cos when I fitted mine as per pic2 my std alloys hit.
I switched to V6 mondeo ones to keep it stock looking.
with std 2wd disks you mount them as pic2, you should have made it clear in your first post.
Dave - Cheers mate, thats what i thought. Wasn't 100% sure tho
McPikie -
DazC - I'm getting the correct bells and rotors off of Mr Rainbird who assures me they will fit.
Moose 130 - I'm working on the same idea as the cossies as they came wiv this brakes behind the original 15" rims, although you prob already knew that
blackRs - Cheers mate.
McPikie -
ACTUALLY ITS THE SECOND PIC!
done this enough times, but as said 4mm needs to be machined off the so that they fit perfectly over standard 2wd disc, if you dont want to do any machining its gonna cost you about £300 to get the correct offset dics, i know which one i would do
Yeah thats'em Adam, can ya stick ya head or camera underneath and snap which side the calliper bolts to the hub as per my top post in this thread.
Adam - Yeah thats cool mate, no perticular hurry.
Gareth -
Just like to plan in my head what i'm doing and how its going to go.
Gareth -
aaah... if its the second pic, you need serious bells or to machine ze calipers
paul, ive got a set of baaad, invincible Wilwood Super light 4 pots sitting here if you want new calipers
If you still got'em when i finally get my finances into gear i may well have'em mate, dont hang onto'em just for little ol me tho.
paceo
Sep 25, 2015 08:05 PM
paceo
Sep 17, 2015 12:12 PM
makaveli96
12
Aug 15, 2015 09:23 PM
