suspec piston rings gone, its alot more.
Old Nov 20, 2005 | 09:37 PM
twinkle_2k86's Avatar
twinkle_2k86
Default suspec piston rings gone, its alot more.
well, i thought i had blown piston rings on my turbo, oh how wrong was i, pull the piston out today as the compression was well down on the bore. and found this.
so know a cheap fix is going to turn into an expensive fix i knew there was a reason not to own a turbo again.
can any one help me on where i can get one piston from, low comp one prefered, but standard is ok, as i can get it all machine to the right spec.
and this piston is a AE one, and only 3500 miles old, so not sure if its a dodge piston, or just a crap make?? or just my cars not running right at all.
Old Nov 21, 2005 | 09:16 AM
davidnormanuk's Avatar
davidnormanuk
I had the same problem with my Mahle Pistons. 3 out of 4 were like yours. Found it was down to detonation in the end. You need to check your timing and compression ratio You head might have been skimmed too much causing the compression to be too high.
Old Nov 21, 2005 | 09:31 AM
twinkle_2k86
once its all fixed, it will be on the rolling road for sure, the timing may well have been wrong, as it was fixed only a tyear ago, maybe it was out. i brought the car with the broken engine, so i dont know how long it had been like this.
cheers for the advice, i will defo get it all checked out
Old Nov 21, 2005 | 10:34 PM
ronf42's Avatar
ronf42
one of my pistons is exactly the same . i need to get hold of another 0.5mm oversize.
you could try burton power or woodford garage motorsport(not sure if they sell single , but burtons will)
Old Nov 22, 2005 | 09:18 AM
Rick's Avatar
Rick
Quite common for the ring lands to go. Would defo use a mahle piston though.
Old Nov 22, 2005 | 08:05 PM
JimmyFlo's Avatar
JimmyFlo
i had thaton my newblock that i put in just rebuilt the whole lump and then got it runnin with low comp on one cylinder.took it apart and whipped the pistons out to find a melted piston. dunno where my mate got the piston fromtho and it was only a standard one.
Old Nov 22, 2005 | 08:14 PM
Rick's Avatar
Rick
That isn't a melted piston. It's not got hot. It's due to excess compression pressure, usually det.
Old Nov 22, 2005 | 08:40 PM
Oranoco's Avatar
Oranoco
Least your piston didn't look like mine
Old Nov 23, 2005 | 07:56 AM
ivorbiggun's Avatar
ivorbiggun
Just cos it was on a rolling road doesn't mean the operator knew his arse
from his elbow.
I've five (count them) 5 engines just like yours,in my basement that
were set up by the various 'experts' around the rather large city I live in.
2 things seem to have cured this,-
1, run the thing on AVGAS and ALDON OCTANE BOOSTER if you can't
get your local airfield to sell you the stuff LARGE TESCO'S now sell
99 (better than Optimax) octane and just put more Aldon in it.
2, you will have to run it on pump fuel occaisionally, so get it set
up by Jamie at Jamsport as he seems to be the only person in the
south (OOOH CONTROVERSIAL) who cares about your car,knows whats for sitting on/leaning on a bar and does a cracking job.
Old Nov 23, 2005 | 08:19 AM
ivorbiggun's Avatar
ivorbiggun
Of course it's also a well known fact that if you don't blow your mota
up from time to time, that,-
1,You is a bit of a girl.
and or
2, You just ain't trying hard enough
I read it in the Haynes so it must be true..........................
Now where did I put my Lithium...........!
Old Nov 23, 2005 | 08:30 AM
ivorbiggun's Avatar
ivorbiggun
Obviously joking about cr*p rolling road operators out there......
I'm sure they all have a very comprehensive knowledge
garnered from studying long and hard to gain their many
formal and recognised qualifications.
Obviously the Lithium hasn't kicked in just yet.....!
Quack
Old Nov 23, 2005 | 08:41 AM
ivorbiggun's Avatar
ivorbiggun
Hello
Is that Messers Sue,Grabbitt and Runne?
There's this bloke on Passion Ford who's suggested I'm
a *ukwit.....
But I have got my twenty five yards breast stroke/I
just can't find the certificate.....
But the game could be up......
Yes, he's taking Lithium...........
So he's clinically insane and there's no chance of prosecution....
And........
Oh that was your Cosworth was it?
Oh dear.........
Well you should have read the small print before
giving it to us....................
Click brrrrrrrrrrrrrrrrrrrrrrrrrrrr!
Old Nov 23, 2005 | 11:43 AM
andre_k's Avatar
andre_k
riiiiiiiigggggggggghtttttttttttttt
Old Nov 23, 2005 | 12:07 PM
T28 RST's Avatar
T28 RST
Ok then
Originally Posted by ivorbiggun
Hello
a *ukwit.....
And........
Oh dear.........
How much of a FANNY is this guy
Old Nov 23, 2005 | 01:53 PM
stusfesta's Avatar
stusfesta
well he has definatly lost me?!!
Old Nov 26, 2005 | 02:04 PM
fightingtorque's Avatar
fightingtorque
i work for a company that makes pistons, and isn't mahle. AE is not a crap make but.....
the ERST piston was originally suplied by mahle. i think they may have used a forged piston, i know ours are cast. but they should still be ok for the original application (not necessarily for a 20 psi monster tho).
on the subject of melted pistons, the max temp your piston should see if your petrol engine is correctly set up (and isn't a top fuel dragster) is about 300C, and aluminium melts at about 600 depending on the alloy.
as was pointed out earlier, these 'melted' pistons are invariably destroyed by detonation, not melting.
Nov 1, 2015 06:53 PM
PRO-LINE MOTORSPORT
Sep 28, 2015 09:54 PM
deathrider666
Sep 28, 2015 06:12 PM
