Another Nos Q! Micro switch thingy!
Right i've nearly finished my Nos install but am not too keen on the micro switch thing that activates it on the throttle body! Is there a better way ie via the tps or something? If not where exactly do you fit the micro switch on the throttle body as i can't suss it out??? A pic of one installed in as much detail as poss would be cool
Originally Posted by Rs Gus
its a black box that triggers from tps input
i have 1 but its not for a cossie m8
What did you use mate?
Originally Posted by Phil
Can you not use the Water Injection output on your SECS monitor to trigger it at whatever throttle you like?
Originally Posted by Steve3door
Get a TPS switch from Trev @ Wizards..... you can even "dial" in when you want the gas to come in so it doesn't have to be on full throttle
Cool will give them a call Monday
Got a website addy for them Steve?
Cheers...
mark94
Ford Mondeo Including ST
Oct 10, 2023 06:52 PM
rsguy
44
Sep 29, 2015 03:29 PM
