Front Hubs - Series 2
Old Nov 16, 2005 | 09:06 AM
John Laverick's Avatar
John Laverick
Default Front Hubs - Series 2
Does anyone know where I can get a pair of these other than Ford?
[For want about £90 each ]
Has anyone else experianced problems with these wearing out?
Old Nov 16, 2005 | 12:09 PM
Ginge !'s Avatar
Ginge !
just finding my feet
you found the problem then
usually worn bearings then alloy the hub to wear off line
its made my brakes warp too
after that then mesure the brakets JUST incase they are off line too
Old Nov 17, 2005 | 09:34 AM
John Laverick
Haven't found the problem....but theres not much else it can be!!
I'm gonna fit new hubs and bearings and see if that stops my brakes warping
Old Nov 17, 2005 | 09:51 AM
Ginge !'s Avatar
Ginge !
have you cheacked the brackets are true though, im about to make a conversion myself and thought about your brake problem ect
Old Nov 17, 2005 | 10:16 AM
John Laverick
I haven't checked to see if the brackets are true to be honest.....I've not touched the car for a few months!! I just want to get it sorted for the track day season next year!!
I don't think the brackets not being true would cause the discs to warp though....wear the pads uneven/squel etc.. but not warp.
Old Nov 17, 2005 | 11:59 AM
AndyRST's Avatar
AndyRST
john i had to change my hub knuckle and hub because of massive play when the hub nut came undone while on track.
I managed to get a good 2nd hand hub knuckle and a brand new hub from a local small parts place. Think i payed around £30 for the hub and was made in germany and top quality
John you want me to pop in and see if they have any more of these hubs instock
Old Nov 17, 2005 | 12:45 PM
Ginge !'s Avatar
Ginge !
john the way i was thinking about it was the calipers force ect would twist it im sure and as a result under harder braking may force it
oh and you got a PM for another mater
Old Nov 17, 2005 | 01:11 PM
John Laverick
Andy,
My hub nuts not coming loose but I think worn hubs may be the cause of my brakes warping all the time.
When you say 'Hub Knuckle' do you mean the stationary piece that the shick absorber/anti-roll bar / track rod end bolts to? And the bearing fits inside? What wears on this piece?
If you could find out about the new hubs it would be appreciated
Was it a motor factors? I assumed nobody but Ford would do this part.
I noticed PF Nick had the same problem as you in this months PF.
Old Nov 17, 2005 | 01:14 PM
dojj's Avatar
dojj
Resident Wrestling Legend
would it not be possible to get the hub face machined flat and true?
if you are going to shell out a efw quid at least you can eliminate that as a source of your porblems
have you measured the run out on the disc with a dial test thingy?
it might also show up as bearings on the way to being shagged
Old Nov 17, 2005 | 01:18 PM
John Laverick
Also a local engineering shop said they could re-chrome the hubs and machine them back to the standard spec. Then machine the mounting face which I think is a good way to go.
Old Nov 17, 2005 | 07:27 PM
AndyRST's Avatar
AndyRST
Hub knuckle yes as you describe it holds everything including the track for the wheelbearings If thats worn you will find that the wheelbearing track will fit in far too easy. They should be a very tight fit and need a large socket and a hammer to fit them in correctly. If the track is slotting in or even spinning round in the metal knuckle then its worn.
Also the track that fits on the hub itself should be a tight fit and no play at all!
TBH i cant see that it would be that causing your discs to warp, but it could cause virbration under braking causing a feeling like there warped.
I'll try and pop in there and see if they got anymore Hubs instock
Old Nov 17, 2005 | 07:43 PM
Ginge !'s Avatar
Ginge !
andy they would cause the disks to warp as the disk may be running at a angle so feel as if there warped
the part that wears is the actual hub not the carrier as in a bearing kit you will notice that the carrier has a removable bearing surface so when you replace the bearing you replace that surfacem the hub though runs on the bearing and so that gets the wear
remember the brake caliper is on the carrier and the disk on the hub so if the disc runs true on the hub with a DTI gauge then the brakets could possibly be bent as i mentioned before
this is all infomation that ive gathered over the last 2 weeks as ive got brake problems at the moment caused buy a bearing just collapsing with no noise mention at all and its happened 1 year after it failed the MOT last time for wear in the bearings which they fixed
good luck and tell me what you find
Old Nov 17, 2005 | 08:29 PM
AndyRST's Avatar
AndyRST
So as i said in my previous post, the disc might not actualy be warped it might just feel like its warped
Old Nov 17, 2005 | 08:57 PM
Matt_B's Avatar
Matt_B
i have a wheel wobble on mine between 60-70mph and when i hold the brakes on hard i get a vibration after a while(of them being on constantly) what is this?
Old Nov 17, 2005 | 09:04 PM
Ginge !'s Avatar
Ginge !
yes biut the twisting motion when braking i was thinking might actually warp the brakes ( as theres no otherway iv managed to warp my brakes in 200 miles driving gentle )
Old Nov 17, 2005 | 09:06 PM
Ginge !'s Avatar
Ginge !
cheack thw wheel balances mate before you look at otherthings as its not only 5 quid its a job that you dont get dirty with
Old Nov 17, 2005 | 09:28 PM
dojj's Avatar
dojj
it could also be something as simple as the bushes being shot
Old Nov 17, 2005 | 09:31 PM
Ginge !'s Avatar
Ginge !
not for johns problem i hope
Old Nov 18, 2005 | 09:18 AM
John Laverick
Guys
The brakes are deffo warping as I had them skimmed....put them back on and the problem was solved.....then it came back.
I a whole track day with them....=lots of abuse with no problems. But then within 1000 miles of light braking on the road the problem was back
I'll get my clock gauge out one day and take some measurements. Its just toooooooo cold at the moment
Andy,
I have replaced both bearings quite recently and changed the bearing tracks which were a very tight fit.
BUT when I push the hub into the bearing it is a very easy push/pull fit. Should this be a tight as well??
Old Nov 18, 2005 | 09:28 AM
John Laverick
Oh and its deffo not bushes!!!
I've replaced nearly everything on the front end now
Old Nov 18, 2005 | 10:25 AM
dojj's Avatar
dojj
perhaps the bushes are exagerating the problem then?
Old Nov 18, 2005 | 11:03 AM
John Laverick
Not sure what you mean??
Its got new bushes on the front
Old Nov 18, 2005 | 11:32 AM
AndyRST's Avatar
AndyRST
Yes the bearing which fits on the hub has its own track that should also be a nice tight fit, not as tight as the track is to get into the hub nuckle tho.
You should be able to feel if theres any play when you fit the bearing onto the hub, there should be none and quite tight
Old Nov 18, 2005 | 01:23 PM
Ginge !'s Avatar
Ginge !
as andy says
doj, you saying that if the nackard bushes aint the cause of the problem the new bushes are now
Old Nov 24, 2005 | 08:59 AM
IANS2RST's Avatar
IANS2RST
noticed u have deflex bushes john. try changing to powerflex on the front.
I had the deflex collapse on the outer tca on the sapph & it caused similar problems. u don't notice the play until it gets really bad
have fitted deflex bushes to an old series 2 as well & they are crap, never again
Old Nov 24, 2005 | 09:02 AM
John Laverick
Ah good thinking Ian...worth a try I suppose
jessie_rs
11
Jun 3, 2019 04:57 PM
Steve Escos
Ford Focus ST Parts for Sale
Oct 19, 2015 05:34 PM
FlashRS
13
Aug 31, 2015 06:02 PM
C2 MAK
Aug 20, 2015 09:46 PM
track.focus'd
Aug 12, 2015 05:53 PM
