View Poll Results: What Cam's do you use?
BD 12's
0%
Voters: 24. You may not vote on this poll
Please Vote: Cosworth Camshaft. Which do you use???
Ive had a lengthy conversation with Piper Cams, and my understanding was that most people opted to use standard cams for upto 400BHP......
However, Piper says this is not the case, and the Cosworth Cam is one of there best selling ones
I'd like to know therefore in order to respond to Piper's claim just how many people are using Non standard cams.......
Copying others wont really help unless you know how they are timed in, run a set of BD14s with too much overlap and you will end up with a car thats way down on power in the midrange for example.
What is it you are trying to achieve, and whats your current spec?
I would worry less about what others are doing and more about what you actually need for your own purposes.
"other"
custom cams by karl in mine, similar lift/duration to somewhere inbetween a 14/15 i think
i asked for a low lag car and thats what i got
t34, headwork
they MUST be matched to the turbo and head by someone who knows what they are doing whatever you use
t34, headwork
Adam Graham
Sep 6, 2015 06:04 AM
. The OE cams are MEGA and you're wasting your time changing them with 803 injectors or below.
