flywheel balanced to the crank???? wtf????
Old Nov 14, 2005 | 06:51 PM
Dicko&Vacant's Avatar
Dicko&Vacant
Default flywheel balanced to the crank???? wtf????
with regards to other days thread.... i did the clutch and replaced flywheel with a skimmed one..... and car is still really badly vibrating in low gears... however if you put foot on clutch and dip it, the vibrating stops, it gets really bad the higher up the rev range you go in each gear..... im being told 100 different things, someone mentioned that the flywheel might need balancing to the crank??? anybody shed any light on the subject? really cant be arsed to have to take crank out though
Old Nov 14, 2005 | 06:53 PM
Graceland's Avatar
Graceland
Team HOTHOT!
if the vibration stops when you dip the clutch, that to me, would suggest that the spinner plate is out of balance and everything else is ok
Old Nov 14, 2005 | 11:17 PM
stu21t's Avatar
stu21t
if your going to take out the clutch u might as well change it all but esp. the release bearing
might as well do the pilot bearing to for what it costs that can cause grief
Old Nov 16, 2005 | 06:38 PM
Dicko&Vacant
anymore help?
Old Nov 16, 2005 | 06:51 PM
-beefy-'s Avatar
-beefy-
formerly beefy-rst-2
yeah sell the car to me sunshine !!!!
i do you a really good deal for a s2 without a motor lol
alrite bud
Old Nov 16, 2005 | 07:02 PM
Tim's Avatar
Tim
Engine mounts.prop shaft bearing etc
Old Nov 18, 2005 | 08:13 PM
Dicko&Vacant
alrite bud
its a shed..... and you would only wreck it like the last car he gave ya.....
Sarah
Old Nov 18, 2005 | 08:14 PM
Dicko&Vacant
have noticed now that when the car is in neutral while running at 70mph it stops vibrating considerably, and also when the clutch is dipped???? surely that must be a flywheel problem? but i can still feel vibrating when going round corners as if there is something catching
Old Nov 18, 2005 | 08:18 PM
Billabong's Avatar
Billabong
Off at a tangent I know, but might be worth checking exhaust clearances, condition of the prop doughnut etc..
mk3cosworth's Avatar
mk3cosworth
you not sorted this yet, bring it down 2moro why i have a butchers, lol
Old Nov 18, 2005 | 08:21 PM
Dicko&Vacant
nah have i fook its vibrating its tits off
Old Nov 20, 2005 | 03:58 PM
jacko's Avatar
jacko
with vibrations like that might get it sold at an ann summers party
Old Nov 21, 2005 | 05:52 PM
Dicko&Vacant
jacko do u still want sarah to order that rampent rabbit for kelly
Old Nov 21, 2005 | 05:59 PM
Dean Saff's Avatar
Dean Saff
wouldn't say it was the flywheel as this spins all the time regardless if the clutch is pressed so you would get vibrations all the time.
I had this prob a while back did you split the prop from the doughnut? if so I'll bet it's that. as they never go back the same shape.
arkeye
Ford Focus ST
Feb 20, 2016 01:22 PM
Mark_
14
Jan 16, 2016 05:27 PM
Jman-pat
Ford Focus Diesel
Nov 8, 2015 01:29 PM
Nov 1, 2015 06:53 PM
