Super power loss and big bangs
Old Nov 14, 2005 | 06:43 PM
Stu.H's Avatar
Stu.H
Default Super power loss and big bangs
I seem to have developed a problem under boost, it seems to be more common in higher gears when on full chat.
I lose ALL power for like 1 second, then SOMETIMES there are LOUD pops straight away, but then back to normal.
I thought it may be coil related, Tony C thinks possible spark plug blow-out?
Not testing tony's theory, just wondered if anyone else has had this problem, as it proper shit me up the 1st time, thought the snails head had blown off
Cheers guys!
Old Nov 14, 2005 | 06:44 PM
ECU Monitor Enthusiast
Crank or phase sensor or fuel starvation !!
Spark blow out doesnt usually cause bangs and pops !
Old Nov 14, 2005 | 06:45 PM
DanRSturbo's Avatar
DanRSturbo
Overboosting ?
Old Nov 14, 2005 | 06:46 PM
Stealth Bomber's Avatar
Stealth Bomber
Sounds like my Cossie at the moment! Will be keeping an eye on this thread
Assuming its a cossie you have
Old Nov 14, 2005 | 06:47 PM
Stu.H's Avatar
Stu.H
car has recently been set up by Karl, so doubt its an afr prob.
Stu.H's Avatar
Stu.H
s2
Old Nov 14, 2005 | 06:49 PM
DanRSturbo's Avatar
DanRSturbo
Is it hitting the rev limiter ?? Are all the pipes around the turbo / actuator on properly ??
What psi boost it showing ?
Old Nov 14, 2005 | 06:50 PM
abdr500's Avatar
abdr500
sounds like you are blowing out the spark or your ingnition amp thats comon 2
Old Nov 14, 2005 | 06:52 PM
Stu.H's Avatar
Stu.H
it gets nowhere near the limiter, a common time is like 90 in 5th lol
all the pipes on fine.
boost is 1.3 - 1.4 spike, 1.1 held.
Thanks for the replies so far guys!
Nov 1, 2015 06:53 PM
Fudgey
21
Sep 30, 2015 06:19 PM
Nick 172 Sport
Sep 28, 2015 07:21 PM
deathrider666
Sep 28, 2015 06:12 PM
