difficult clutch question. help pls
Old Nov 14, 2005 | 04:44 PM
stu21t's Avatar
stu21t
Default difficult clutch question. help pls
i am after a bit of help
i am using a cossie engine mated to a renaul un1 gearbox/transaxle
i thought it was a common conversion but cant find any info on the web about it
my problem is finding a clutch that will work with this.
i want to use a std cossie clutch cover and AP 6 paddle centre plate thats not a problem.
the problem is what release bearing i can use.
i need one that will work with the renault fork, and shaft (29mm) and also meet the fingers on a cossie clutch cover.
can any1 on here help me? or know any1 that can?
i have been searching for over a week but cant come up with anything
cheers
Old Nov 14, 2005 | 05:19 PM
stu21t's Avatar
stu21t
any1?
i thought rs200 replicas used this setup?
Old Nov 14, 2005 | 05:46 PM
Jay,'s Avatar
Jay,
Sponsor
Default Re: difficult clutch question. help pls
cheers
stu think the box is heavily modified with a different shaft and gears diff ect because the un1 gives up at over 300lb have a word with sibley he knows a bloke who builds em for gt40 kit cars hes ya best bet
jay
Old Nov 14, 2005 | 05:53 PM
Jay,'s Avatar
Jay,
Sponsor
http://www.bell-performance.co.uk/gearbox%20upgrade.htm
think this is the bloke
jay
Old Nov 14, 2005 | 06:06 PM
stu21t's Avatar
stu21t
cheers jay but sibley dont know shit
lol
he just thinks he does
the box isnt going to be a problem for me,
but ive spoken to derek and ive got my name on the list for a new shaft one mine does break.
until then i need a bloddy release bearing to use the car. lol
Old Nov 14, 2005 | 06:11 PM
Jay,'s Avatar
Jay,
Sponsor
just spoke to dave he knows a guy his bizz is based on un1 build to any spec required from forks to release bearing to straight cut gears and quaif lsd would u like the num
jay
Old Nov 14, 2005 | 06:22 PM
stu21t's Avatar
stu21t
is it kevin?
i had his number but lost it
yeah if u got the number pls m8.
Old Nov 14, 2005 | 06:32 PM
Jay,'s Avatar
Jay,
Sponsor
is it kevin?
dave said call him hes got it sum where
jay
Old Nov 14, 2005 | 06:33 PM
stu21t's Avatar
stu21t
lol ok m8
cheers
Old Nov 16, 2005 | 07:04 AM
Jay,'s Avatar
Jay,
Sponsor
right stu the clutch is the same diameter as as the 21 u can use a 21 clutch late a cossie cove and bearing amd u need a bush made up to spce the input shaft
my way modify the cossie fly wheel to to take the reno clutch and then use a paddle clutch for the extra power u have gained hth
jay
or heres a idea take ur quad apart get a cossie beam madified and rwd it thatll be fun
Old Nov 17, 2005 | 11:11 PM
stu21t's Avatar
stu21t
cossie clutch is 240mm
reno is 235
bearings wont work from either.
ive got a bearing on its way to me now
and will use a std 4x4 cossie cover with an ap centre.
just need to find out about the input shaft spacing now, but i would have thought the bell housing would have been made so the input shaft was in the correct position?????????
Old Nov 18, 2005 | 06:48 AM
Jay,'s Avatar
Jay,
Sponsor
reno is 235
nope it doesnt think ull need a 10mm bush also make sure that cover fits coz andy rabson spent 450.00 ona a cossie converted clutch and cant get the gearbox over it
jay
mark94
Ford Mondeo Including ST
Oct 10, 2023 06:52 PM
mk3ste
Oct 17, 2021 10:09 AM
arkeye
Ford Focus ST
Feb 20, 2016 01:22 PM
PRO-LINE MOTORSPORT
Sep 28, 2015 09:54 PM
