Tools and their uses.... my ribs hurt!!
Old Jul 9, 2004 | 09:35 AM
3doorPete's Avatar
3doorPete
Default Tools and their uses.... my ribs hurt!!
HAMMER: Originally employed as a weapon of war, the hammer nowadays is
used as a kind of divining rod to locate expensive parts not far from
the object we are trying to hit.
MECHANIC'S KNIFE: Used to open and slice through the contents of
cardboard cartons delivered to your front door; works particularly well
on boxes containing seats and motorcycle jackets.
ELECTRIC HAND DRILL: Normally used for spinning steel Pop rivets in
their holes until you die of old age, but it also works great for
drilling mounting holes just above the brake line that goes to the rear
wheel.
PLIERS: Used to round off bolt heads.
HACKSAW: One of a family of cutting tools built on the Ouija board
principle. It transforms human energy into a crooked, unpredictable
motion, and the more you attempt to influence its course, the more
dismal your future becomes.
MOLE-GRIPS: Used to round off bolt heads. If nothing else is available,
they can also be used to transfer intense welding heat to the palm of
your hand.
OXYACETELENE TORCH: Used almost entirely for lighting various flammable
objects in your garage on fire. Also handy for igniting the grease
inside a brakedrum you're trying to get the bearing race out of.
WHITWORTH SOCKETS: Once used for working on older cars and motorcycles,
they are now used mainly for impersonating that 9/16 or 1/2 socket
you've been searching for for the last 15 minutes.
DRILL PRESS: A tall upright machine useful for suddenly snatching flat
metal bar stock out of your hands so that it smacks you in the chest and
flings your beer across the room, splattering it against that freshly
painted part you were drying.
WIRE WHEEL: Cleans rust off old bolts and then throws them somewhere
under the workbench with the speed of light. Also removes fingerprint
whorls and hard-earned guitar callouses in about the time it takes you
to say, "F...."
HYDRAULIC FLOOR JACK: Used for lowering car to the ground after you have
installed your new front disk brake setup, trapping the jack handle
firmly under the front fender.
EIGHT-FOOT LONG DOUGLAS FIR 2X4: Used for levering a car upward off a
hydraulic jack.
TWEEZRS: A tool for removing wood splinters.
PHONE: Tool for calling your neighbour to see if he has another
hydraulic floor jack.
SNAP-ON GASKET SCRAPER: Theoretically useful as a sandwich tool for
spreading mayonnaise; used mainly for getting dog-doo off your boot.
BOLT AND STUD EXTRACTOR: A tool that snaps off in bolt holes and is ten
times harder than any known drill bit.
TIMING LIGHT: A stroboscopic instrument for illuminating grease buildup.
TWO-TON HYDRAULIC ENGINE HOIST: A handy tool for testing the tensile
strength of ground straps and brake lines you may have forgotten to
disconnect.
CRAFTSMAN 1/2 x 16-INCH SCREWDRIVER: A large motor mount prying tool
that inexplicably has an accurately machined screwdriver tip on the end
without the handle.
BATTERY ELECTROLYTE TESTER: A handy tool for transferring sulfuric acid
from a car battery to the inside of your toolbox after determining that
your battery is dead as a doornail, just as you thought.
AVIATION METAL SNIPS: See hacksaw.
INSPECTION LIGHT: The mechanic's own tanning booth. Sometimes called a
drop light, it is a good source of vitamin D, "the sunshine vitamin,"
which is not otherwise found under cars at night. Health benefits aside,
its main purpose is to consume 40-watt light bulbs at about the same
rate as 105-mm howitzer shells during the Battle of the Bulge. More
often dark than light, its name is somewhat misleading.
PHILLIPS SCREWDRIVER: Normally used to stab the lids of old-style
paper-and-tin oil cans and splash oil on your shirt; can also be used,
as the name implies, to round off Phillips screw heads.
AIR COMPRESSOR: A machine that takes energy produced in a fossil-fuel
burning power plant 200 miles away and transforms it into compressed air
that travels by hose to a pneumatic impact wrench that grips rusty bolts
last tightened 30 years ago by someone in Dagenham, and rounds them off.
PRY BAR: A tool used to crumple the metal surrounding that clip or
bracket you needed to remove in order to replace a 50 cent part.
HOSE CUTTER: A tool used to cut hoses 1/2 inch too short.
Old Jul 9, 2004 | 10:59 AM
StephenC's Avatar
StephenC
..BS Motorsport..
disconnect.
classic
Old Jul 9, 2004 | 01:20 PM
Lemon S2's Avatar
Lemon S2
Some of them sound far too familiar
very good though
Old Jul 9, 2004 | 05:06 PM
Stu @ M Developments's Avatar
PassionFords Creator
Moved here by me so others can feel the pain im feeling from laughter
Old Jul 9, 2004 | 05:08 PM
TIFF's Avatar
TIFF
Chasing Radders
Old Jul 9, 2004 | 05:10 PM
Phil's Avatar
Phil
Jeebus
Soooo true
Old Jul 9, 2004 | 06:18 PM
Greg Shepherd's Avatar
Greg Shepherd
Chasing Radders
FPMSL
Old Jul 9, 2004 | 06:28 PM
3drstretch's Avatar
3drstretch
RS-Rikki
Sep 21, 2015 07:27 AM
grishenko45
Sep 9, 2015 12:58 PM
Rizlablue
Sep 6, 2015 10:54 AM
Rizlablue
Sep 6, 2015 09:58 AM
hopper350
Sep 4, 2015 12:53 AM
