only luke warm
Old Nov 13, 2005 | 10:44 PM
twitchyrear's Avatar
twitchyrear
Default only luke warm
why is my heater only giving out luke warm air in my saff cos? i was cold on the way to donny today
Old Nov 13, 2005 | 10:50 PM
Stu.H's Avatar
Stu.H
knackered or no thermostat
same prob on my s2
Old Nov 13, 2005 | 10:52 PM
twitchyrear
cheers stu,that had crossed my mind,ill have a look 2mrw
Old Nov 13, 2005 | 10:58 PM
Rick's Avatar
Rick
if temp gauge is in nomral position, then it's a blocked heater matrix, air lock, or ur running low on water.
Old Nov 13, 2005 | 10:59 PM
twitchyrear
the temp gauge is in norm position,water lev is fine and sure theres no air lock,how do i tell if heater matrix is shagged???
Old Nov 13, 2005 | 11:16 PM
twitchyrear
upski
NUTS RuS's Avatar
NUTS RuS
Originally Posted by twitchyrear
the temp gauge is in norm position,how do i tell if heater matrix is shagged???
Does it have a blue oval badge on the front ?
Old Nov 13, 2005 | 11:18 PM
twitchyrear
not sure mate but will check tomorrow
boost mad's Avatar
boost mad
i have a similar prob, my matrix is fine and i have a thermo, there is no air lock and im not low on water but i also get colder air out of one side of the vent
Old Nov 13, 2005 | 11:30 PM
twitchyrear
,we need it sorting mate with the cold coming
Old Nov 14, 2005 | 01:38 AM
EssexMikeSi's Avatar
EssexMikeSi
funny that this post is up as ive been out inmy s2 tonight and cant get hot air in the car. ok, my middle 2 vents are no longer there due to gauges now there but air comin out the other 2 vents is only a tiny bit warm.
i know my heater matrix needs replacing as its dripping. could this be whats causing no real heat?
Old Nov 14, 2005 | 07:33 AM
NUTS RuS's Avatar
NUTS RuS
Yep they will be blocked
cossie362
Oct 11, 2015 03:53 PM
Shaunc
Escort Range
Sep 23, 2015 06:00 AM
pabloXR
Sep 21, 2015 12:42 PM
xrmalin
Sep 13, 2015 06:52 PM
stevierob
Sep 7, 2015 07:09 PM
