General Car Related Discussion.To discuss anything that is related to cars and automotive technology that doesnt naturally fit into another forum catagory.
Is there a simple way to test of the start motor is nackered? Car has suddenly stopped working for no apparent reason. Turn the key and all the usual noises happen (fuel pump etc) but nothing when i turn the key the last notch. Got to be starter related, but is there an easy way to check before i replace it?
put the car in gear, push it forward a tuny bit then take out of gear and see if the starter chucks in, i remember myu old orion had a sticky point thingy and i had to hit it with hammer to unstick it
never knew how easy it is to change a starter motor
