So will a ERST Run unleaded? OR it need to be LRP
Old Jul 8, 2004 | 08:38 PM
L33 BYT's Avatar
L33 BYT
Default So will a ERST Run unleaded? OR it need to be LRP
As above.
Old Jul 8, 2004 | 08:40 PM
Tony Turbo's Avatar
Tony Turbo
www.ctuceilings.co.uk
Diesel
Old Jul 8, 2004 | 08:41 PM
Dead and Gone's Avatar
Dead and Gone
Used to run mine on the good unleaded stuff
L33 BYT's Avatar
L33 BYT
Probably make mine run better to be honest TT
Old Jul 8, 2004 | 08:42 PM
L33 BYT's Avatar
L33 BYT
YYeah ran my last one on it too. Should the timing be changed.
Old Jul 8, 2004 | 08:52 PM
Dead and Gone
Don't think it should, why whats wrong with yours?
Old Jul 8, 2004 | 08:56 PM
L33 BYT's Avatar
L33 BYT
Nothing mate. Is my new RS not even driven her yet, engine going in this weekend just seeing if many ran on unleaded out there.
Old Jul 8, 2004 | 08:58 PM
Dead and Gone
eye c
AndyRST's Avatar
AndyRST
super unleaded ONLY !
Old Jul 8, 2004 | 09:00 PM
Tony Turbo's Avatar
Tony Turbo
Only if it is chipped
Old Jul 8, 2004 | 09:01 PM
Eagle's Avatar
Eagle
Super Moderator
deffo NO lrp ,,,, its horrrificaly crap
Old Jul 8, 2004 | 09:02 PM
L33 BYT's Avatar
L33 BYT
TT - What u can only use it if chipped or you shouldnt be using normal unleaded if its chipped.
Old Jul 8, 2004 | 09:03 PM
Billabong's Avatar
Billabong
Super Unleaded!! regardless of wether chipped or not - RST's were designed for Leaded fuel orginally (Last of the turbo's actually stated SUL in the brochure once 4* died a death), LRP no good. You can use NUL only if you have the timing retarded (assuming late head)
Tony Turbo's Avatar
Tony Turbo
Originally Posted by RST_lee
... or you shouldnt be using normal unleaded if its chipped.
Yup
Old Jul 8, 2004 | 09:05 PM
AndyRST's Avatar
AndyRST
As per Billabong, chipped or not should run it on Super unleaded only to be safe
Tony Turbo's Avatar
Tony Turbo
Not what my mate Chris says
Old Jul 8, 2004 | 09:06 PM
L33 BYT's Avatar
L33 BYT
Doesnt MR Norris do Lean Burn Heads
Old Jul 8, 2004 | 09:08 PM
McPikie's Avatar
McPikie
Optimax is the way forward
Old Jul 8, 2004 | 09:17 PM
AndyRST's Avatar
AndyRST
you mean MY mate chris
Old Jul 8, 2004 | 09:28 PM
Billabong's Avatar
Billabong
Your mate Chris is wrong then
Old Jul 8, 2004 | 09:50 PM
Jim Galbally's Avatar
Jim Galbally
no reason you cant run one on 95ron tescos shit as long as you get it set up on this fuel.
notice how when you loosen that bolt on the right hand side of the engine you can actually TWIST the distributor this beleive it or not actually does something
Old Jul 8, 2004 | 10:55 PM
Billabong's Avatar
Billabong
Jim
Bill
Old Jul 9, 2004 | 09:42 AM
kevsrs's Avatar
kevsrs
I thought everyone used optimax
That's what i changed to when i couldn't get LRP anywhere and it runs much sweeter
I'd recommend it
Old Jul 9, 2004 | 09:46 AM
CabrioTurbo's Avatar
CabrioTurbo
Lol so did i or super at least... dont understand why anyone would want to run an RST on NUL unless your a cheapskate or bought the car for its looks not how it goes
Old Jul 9, 2004 | 10:15 AM
adamS2RST's Avatar
adamS2RST
Always user super, stop being a cheapster Lee and dont use crappy unleaded, mines not chipped but still wont run it on shit
Old Jul 9, 2004 | 10:34 AM
Billabong's Avatar
Billabong
When I'm referring to NUL (95 RON) and SUL (97RON or greater) I'm not referring to brand, but grade of fuel i.e. either 95 or 97+ RON. I find it surprising, and a little disturbing that people think a standard ERST should use 95RON fuel!
Old Jul 9, 2004 | 10:47 AM
kevsrs's Avatar
kevsrs
Well i'm afraid it don't know my NULs from my SULs
Old Jul 9, 2004 | 10:49 AM
Billabong's Avatar
Billabong
Not a dig Kev, just clarifying
Old Jul 9, 2004 | 10:57 AM
kevsrs's Avatar
kevsrs
No bother, it's asking daft questions and sayin stupid things where i learn most stuff on here
Old Jul 9, 2004 | 03:36 PM
flashpoint's Avatar
flashpoint
Cheep stuff in my every day car and supper or optimax in the other
Steve
Old Jul 9, 2004 | 03:56 PM
Jim Galbally
just relaised we all completely missed the point of this post
a SERIES 2 RS TURBO has hardened valve seats so does NOT require leaded fuel/LRP/Lead Additives
ie you can run it on unleaded fuel without risk of damaging the head
i THINK some of the early S1s might not have this done, but i dont know for sure (ive forgotten )
also LRP is SHIT far better off using unleaded fuel + lead additives
Old Jul 10, 2004 | 12:49 AM
kevsrs's Avatar
kevsrs
Or Optimax?????? Am i right?????
Old Jul 10, 2004 | 12:58 AM
Billabong's Avatar
Billabong
Speak for yourself Jimbo ALL RST's were mapped to run LEADED fuel, or when that was all but phased out in normal use, SUL was deemed acceptable without further adjustment (in actual fact, 98RON unleaded fuel - people often forget that SUL used to be 98RON in the good old days....). You are correct about the valve seats, but that's not the real issue
EDITED: spelling
Old Jul 10, 2004 | 01:04 AM
kevsrs's Avatar
kevsrs
Billabong you know far too much about this sh*t
Old Jul 10, 2004 | 01:05 AM
Billabong's Avatar
Billabong
Probably
Old Jul 10, 2004 | 08:22 AM
Boost Junky's Avatar
Boost Junky
As Billabong says.. 100% SUL
Old Jul 10, 2004 | 08:34 AM
Less.'s Avatar
Less.
having a mid life crisis
My old S2 always had super or optimax and same for the RS2K
Old Jul 10, 2004 | 08:39 AM
Rs Gus's Avatar
Rs Gus
impreza wrx sti version 8
isent there 2 wires u can earth out what retards the timing in the ecu???????
Old Jul 10, 2004 | 11:17 AM
Billabong's Avatar
Billabong
That's on a Cossie (and some Vauxhalls) Gus, pretty sure you have to do it via the dizzy on an ERST.
Old Jul 10, 2004 | 03:25 PM
Rs Gus's Avatar
Rs Gus
could ave sworn the erst had them aswell
