rear disk conversion.............
Old Nov 9, 2005 | 03:10 PM
Combi_Chris's Avatar
Combi_Chris
Default rear disk conversion.............
can some one please list all the parts i need to do a rear disk conversion ?
al li have so far is the brackets to hold the calipers............
Old Nov 9, 2005 | 05:41 PM
Davey8oy's Avatar
Davey8oy
mk 5 rs 2000 handbrake cable
cossie 2wd discs
cossie 2wd calipers and brackets
pads
front escort braided lines
and when i got my brackets i got some spacers to put on the handbrake cable to take the slack out of it!
hope this helps
Old Nov 9, 2005 | 05:51 PM
Combi_Chris
thanks davey
Old Nov 9, 2005 | 06:08 PM
Davey8oy's Avatar
Davey8oy
Combi_Chris
no problem!
Old Nov 9, 2005 | 06:17 PM
Micky's Avatar
Micky
Default Re: rear disk conversion.............
Hi mate,make sure youre brackets are designed to work with rear Cossie disc's,as some brackets are for the rear XR4i disc's!!!Regards Micky
Old Nov 10, 2005 | 12:13 PM
Combi_Chris
mickey ill find out when its too late probably, lol
Old Nov 13, 2005 | 05:13 PM
Combi_Chris
so can i use cozzy rear calipers ??
i might be looking at the wrong ones ??
Old Nov 13, 2005 | 05:44 PM
andysrs's Avatar
andysrs
Default rear disc
Mines got golf gti calipers
Old Nov 13, 2005 | 05:55 PM
Combi_Chris
yes i seen that piccy already , why did you choose veedub parts ?
and in case it got missed, can i use rear cozzy calipers???
Old Nov 14, 2005 | 10:16 PM
Combi_Chris
can i use cozzy rear calipers or what ??
Old Nov 14, 2005 | 10:18 PM
rsrob's Avatar
rsrob
read the post
Old Nov 15, 2005 | 12:40 PM
Combi_Chris
i did read it it says cozzie 2wd calipers , so that means front or rear ???
or dont it matter , excuse my ignornace , dont laugh at it
Old Nov 15, 2005 | 10:34 PM
rsrob's Avatar
rsrob
its the 2wd rear disks and calipers you want
Old Nov 17, 2005 | 08:30 PM
NUTS RuS's Avatar
NUTS RuS
Any sierra rear calipers (excpet 4i) as they are all the same
Old Nov 18, 2005 | 02:05 PM
db's Avatar
db
I think you will need the S2 rear brake compensator to get
a good balance in front and rear braking. With rear discs
the back end will brake a lot heavier than before.
Especially under heavy braking the light rear of the MK3/4
will have a tendency to go first without your permission
A friend of mine had to install special balancing equipment
to balance his racing MK3 under heavy braking
Old Nov 19, 2005 | 06:54 PM
Robliddle's Avatar
Robliddle
Default Hand break cable
Hi there mate,
When i converted my escort cabbie to rear discs the hand break used to stick on. this is due to the mk5 hand brake cable.
The horse shoe shaped piece of metal under the car on the mk5 cable is bigger than the one on the mk4 and there for wedges its self in the tunnel under the car and makes the hand brake stick on. so remember to use the horse shoe off the mk4 cable and u will be ok. Just thought this may be worth u knowing!
155lee
Sep 6, 2016 11:10 AM
yatta
May 21, 2016 10:31 PM
The Enigma
Sep 12, 2015 10:12 PM
cossirob
Sep 3, 2015 09:17 PM
