Cossie management S1 inlet
Nov 9, 2005 | 03:01 PM
Whats involved in converting a Series 1 inlet manifold to take the cossie management?
Radleigh
Nov 9, 2005 | 05:28 PM
Freddy_mercury_magic
i got a s1 manifold on mine runnin cossy management!
been told its got better flow rates than the efi fiesta manifold most people use!
see the pics that gadget has posted up in rst bits for sale!
im runnin a cossy throttle body it the normal fasion with the throttle linkage on the left and the tps on the right and a external iscv!
i got the charge temp sensor in me cross over pipe! as im runnin als this is better cos its common to get flames blow back and heats the sensor up and switches the als off if you run it on the other side of the throttle butterfly!
as for coolant temp its runnin in the standard s1 place!
and you have to have mounts welded for the fuel rail!
Nov 9, 2005 | 06:33 PM
Gadgets selling one at the mo....
Nov 9, 2005 | 06:51 PM
Does look nice that inlet
Nov 13, 2005 | 02:13 PM
Cheers for the reply
Nov 14, 2005 | 03:42 PM
I've seen a S1 with Cossie WM and RS1600i-Parts last year:
1850 CVH with Cosworth 4x4 Turbo and management. 200+ up to 300 hp, depends on boost:
Nov 14, 2005 | 04:35 PM
Quote:
Actually, it's the opposite, as flow bench tested by my machinist.
Nov 14, 2005 | 05:13 PM
Tony Turbo
well i got that info off ian howell! and i feel he knows his stuff!
Nov 14, 2005 | 05:44 PM
So do we
Nov 15, 2005 | 05:25 PM
So what would you recommend?
Use the Bottom half of a Fiesta inlet or a S1 inlet, either way the engine is going to have cossie management and a custom top half
Nov 15, 2005 | 08:33 PM
The inlet diameter on the EFI fiesta is larger than the S1/S2 manifolds.
Nov 16, 2005 | 08:11 PM
Cheers..
But what should i do about the injector ports for the head?
Use a plate or get the head machined....
Nov 16, 2005 | 08:59 PM
If you want power, and flow, then use an EFi inlet, I was under the impression that a Cosworth style injector was a direct fit... Are you going for a fancy injector?
Nov 16, 2005 | 09:22 PM
Not sure yet tony, will know in 7 minths when im back in the country and have the ŁŁ to do what i want
Maybe just greys
Nov 16, 2005 | 09:37 PM
They are plenty of injectors above 500cc that will go into a Cosworth style fuel rail. Greys are ok, but I on the limit of mine
Nov 16, 2005 | 09:39 PM
I'll be looking for OVER 300bhp...
How come there on the limit when they fuel 400bhp cossies
Nov 16, 2005 | 09:41 PM
Ooooops sorry, I drifted off there for a sec, one of those micro sleeps
Different engines mate, work in different ways
Nov 16, 2005 | 09:42 PM
Nov 16, 2005 | 09:43 PM
Nov 16, 2005 | 09:45 PM
No, that will never work
Nov 16, 2005 | 09:48 PM
I like your idea about my Porsche though
The shell will need a white respray first set it off, and be a GT3
Other than that I am sorted
Get in!!!
When can i get a go..... I wont put it in a lake like i did my mates marder
Nov 16, 2005 | 09:50 PM
PMSL - It never comes to meets, with my car control I am likely to kill someone
Nov 16, 2005 | 09:51 PM
Its only 2ft big
The R/C car that is
Nov 16, 2005 | 09:59 PM
2.5 actually, and it weighs about 25 pounds and does 70+mph...
I see a slaughter at the Essex Meet
I didn't have it in one piece, otherwise it would have gone to Brunters for a laugh, but I took my assult rifles instead
Nov 16, 2005 | 10:02 PM
Quote:
Originally Posted by Tony Turbo
2.5 actually , and it weighs about 25 pounds and does 70+mph...
Not a bad guess seeing as i havent seen one for over a year
Oh the one i drove, it went into the lake at top speed
WOW what a splash
LOL Nice
Nov 16, 2005 | 10:03 PM
PMSL @ Splash
I bet your mate was happy
Nov 16, 2005 | 10:04 PM
Nov 16, 2005 | 10:08 PM
PMSL
I may take the Porsche to Bedford
Hopefully I will have fine tuned the suspension by then so it will turn without swapping ends lol
Nov 16, 2005 | 10:10 PM
Nov 16, 2005 | 10:11 PM
Yeah.... right
And
YEAH RIGHT!
I might let you watch
Nov 16, 2005 | 10:12 PM
from the passenger seat yeah.. ?
Nov 16, 2005 | 10:15 PM
Will you fit in the Porsche?
There aren't any seats ya know
Nov 16, 2005 | 10:16 PM
Nov 16, 2005 | 10:17 PM
To be serious tho, i would like to go out in your car
As i'd like to feel a genuine 300+bhp S2
Nov 16, 2005 | 10:19 PM
You missed your chance at the Essex Meet lol
I'll take you out for a few laps, just come over when you see me about to go out
If it's raining though the car is staying in the garage lol
Nov 16, 2005 | 10:20 PM
Nov 16, 2005 | 10:26 PM
Bummer
One of the best places to take someone out too.
Let's hope I can drive the RS better than I can the Porsche
