Arrggh!!! what is it wi squeaking brakes!!!!!!
Old Nov 9, 2005 | 11:26 AM
Cawood's Avatar
Cawood
Default Arrggh!!! what is it wi squeaking brakes!!!!!!
what causes brakes to squeak/squeal?
put new pads (just cheapy motoquip) in me RS2k, then they started squeaking really bad whenever you brake,
i've got a 20mile drive to work in stop/start traffic its slowly driving me insane!!
been out and bought another set of pads, thought i'd replace discs as well this time to see if that sorts it, (motoquip discs and ferrodo pads)
guess what its still doing it!!!!!
at first it would start after about 5min of driving or as soon as you stamp on the peddle hard,
with these new brakes you mite make it 10min without it happening now
could it be the calipers causing it?
please help?
Old Nov 9, 2005 | 11:27 AM
vroooom ptssssh's Avatar
vroooom ptssssh
It Wasnt Me!
did you put copper grease on the back of the pads?
Old Nov 9, 2005 | 11:43 AM
cossie4i+'s Avatar
cossie4i+
TT T38 Power
As above
Changed mine and done the same, i did use copper grease but not enough!!!!
Old Nov 9, 2005 | 12:33 PM
cossies4eva's Avatar
cossies4eva
anti rattle things catching on disc ?
Old Nov 9, 2005 | 02:06 PM
Cawood's Avatar
Cawood
ah, how much copper grease is needed?
i did use copper grease, but i may not have put enough on too!
what are these anti rattle things mate?
Old Nov 9, 2005 | 03:02 PM
dojj's Avatar
dojj
Resident Wrestling Legend
the squeak is from the pads rubbing in the carriers
clean them up and refit with a little smidgen of grease on them and it should solve the problem
Old Nov 9, 2005 | 03:16 PM
Jim Galbally's Avatar
Jim Galbally
try braking very hard a few times (give them a good run) and see if they still do it.
mine squeak when the car gets driven like miss daisy, but then they are track spec jobbies.
Old Nov 9, 2005 | 03:26 PM
Rich_w's Avatar
Rich_w
Proven Legendary Status
If more copper slip / GRease doenst solve it. Try sanding the edge of the pads to a 45 degree angle rather than the 90 they are from new.
Only do a few mms though!
Old Nov 9, 2005 | 05:19 PM
MadMac's Avatar
MadMac
Just put some WD40 on it
Disclaimer: Do not do what I say its a stupid idea and your crazy to take it seriously
Old Nov 9, 2005 | 05:24 PM
T28 RST's Avatar
T28 RST
Ok then
Dave take this mans advice, plenty of WD40 and the noise will go away
Old Nov 9, 2005 | 05:32 PM
Mr C's Avatar
Mr C
*ucking ignore that advice mate thats just bloody dangerous!!!!
Grease the contact face of the disk liberally with goose fat and the pad face with GT85, it has teflon in and far better than WD40 IMHO
Old Nov 9, 2005 | 05:33 PM
Mr C's Avatar
Mr C
Oh yeah:
Old Nov 9, 2005 | 06:37 PM
MadMac's Avatar
MadMac
sorry just had to do that.
Since the switch from Aspesdos brake pads they all do it now
Old Nov 9, 2005 | 06:41 PM
T28 RST's Avatar
T28 RST
Ok then
Cawoods that dumb he will probably try it
Old Nov 9, 2005 | 06:42 PM
NUTS RuS's Avatar
NUTS RuS
Turn the radio up
Old Nov 9, 2005 | 06:46 PM
Dean Saff's Avatar
Dean Saff
Dont do this you need to bed the brakes in.
Chances are it's your rear brakes are the standard drums?
Old Nov 9, 2005 | 07:04 PM
Mr C's Avatar
Mr C
Dont brake... simple really
muzzman1
Sep 30, 2015 08:59 PM
Sp3no
Sep 27, 2015 07:23 PM
