When aiming for approx 360ish
Old Nov 8, 2005 | 08:59 PM
Paul Eggleton's Avatar
Paul Eggleton
Default When aiming for approx 360ish
will any major improvements be seen in response/drivability etc through changing cams and or having mild headwork.
Is any benefit worth the extra outlay, or is the std cams and head properly verniered up the best value for money option?
Ta.
Old Nov 8, 2005 | 09:02 PM
Stu @ M Developments's Avatar
PassionFords Creator
I personally love the std cams at this power paul and think anything else is a trade off.
Old Nov 8, 2005 | 09:10 PM
Paul Eggleton
Nice one, thanks Stu
Old Nov 8, 2005 | 09:11 PM
RichardPON's Avatar
RichardPON
About bloody time Paul
Old Nov 8, 2005 | 09:15 PM
PAUL S's Avatar
PAUL S
Originally Posted by Stu @ M Developments
I personally love the std cams at this power Paul and think anything else is a trade off.
is it true that verniers are not the best option to adjust timing on any cam as they expand at different rates causing tension in the belt or is it a myth
Old Nov 8, 2005 | 09:16 PM
Lambchop's Avatar
Lambchop
PF Idiot Sniper
aye what he said
Old Nov 9, 2005 | 07:54 AM
Paul Eggleton
Pon and Chop
OK, the engine has racked up 87K now. Do the cossie cams suffer the same fate as the RST ones in that they wear quite badly? If I have to change the cams because of wear is it then worthwhile getting a different Cam(s)?
Ta
Old Nov 9, 2005 | 08:04 AM
Beach's Avatar
Beach
My car seems fine on the standard head and cams, its very drivable with very little lag, the power and pickup in 4th is unreal from 70 mph
Old Nov 9, 2005 | 08:06 AM
Mike Rainbird's Avatar
Mike Rainbird
Caraholic
Standard cams and 0.48 a/r exhaust if you're sticking with 803s .
Old Nov 9, 2005 | 08:09 AM
Beach's Avatar
Beach
Mines on a .55 but still feels good
Old Nov 9, 2005 | 04:12 PM
Paul Eggleton
Mike, I don't know what I'm doing yet
Old Nov 9, 2005 | 04:16 PM
RichardPON's Avatar
RichardPON
Or stay on the .63 and go to greys?
Old Nov 9, 2005 | 04:26 PM
Paul Eggleton
I may well do that Rich, as I'd like to run a bit of antilag. I'm aiming to get it done for next years GT battle and a september ring trip
Old Nov 9, 2005 | 08:46 PM
Damo V's Avatar
Damo V
Paul who is building it?
Mine is on light blues and std cams, std ish head (new block) all the other gubbins etc
T34 A/R.48 375brake on the dyno, so should easily break 350 in the car, that was my request a SAFE strong 350/360..
Old Nov 9, 2005 | 09:34 PM
JonnyBravo's Avatar
JonnyBravo
Could I still stick with t34 .48 if I chose to go to 400's ? or would the .63 be better?
Old Nov 9, 2005 | 09:42 PM
Damo V's Avatar
Damo V
depends what power you want ?? I wopuld step it up a litle ... be rude not to really if got the cams
Old Nov 9, 2005 | 10:03 PM
JonnyBravo's Avatar
JonnyBravo
My mate has a Harvey Gibbs built engine in his 3 door running 400's
a moddest 380bhp holding 1.9 bar, quite sure its on a .48.
My engine is lowered compression, ported head, standard cams, Level 6, 803's, would like to see about 340bhp from it but interested in taking the power up a bit for when I get it dynoed before it finally goes in my car.
Not sure wether to just leave it as it is as it was good in the car it came from but being a very fresh build and after driving my mates 3 door I do fancy a bit more h/p, and his engine produces the sort of power I think would be plenty in a mk2 escort.
decisions decisions
Old Nov 9, 2005 | 10:07 PM
Damo V's Avatar
Damo V
hang on 400's?? Grey or blue?
Old Nov 9, 2005 | 10:22 PM
JonnyBravo's Avatar
JonnyBravo
sorry lol
I meant 403's blues
should spend more time watching what I'm typing than getting glued to Lost !
Old Nov 9, 2005 | 10:25 PM
abdr500's Avatar
abdr500
400 are blues
Old Nov 9, 2005 | 10:26 PM
Damo V's Avatar
Damo V
yeah thats what mine is
Harvey Gibbs, 375Brake, T34.48 Light blues, 1.8-1.9Bar stdish head etc 7.6:1Comp WRC HG...blah blah blah
Old Nov 9, 2005 | 10:33 PM
JonnyBravo's Avatar
JonnyBravo
eek ! see Damo V you had me confused.
I thought 400's were blues and 403's are greys if I'm not mistaken ! not had the pleasure of having to use injectors like that yet lol
yeh yours is similar to my mates, his car was quite well known round this way from previous owners etc..
cant really miss it now due to it graphics !
anyway, only thing between yours and mine is I'm on a group A gasket,
what ecu you running and who mapped it ?
Old Nov 9, 2005 | 10:36 PM
Damo V's Avatar
Damo V
P8, air to air pectel booard etc etc
Mapped by Harvey and Ahmed on the Dyno... yet to go back and see Ahmed for the final set up though!!!
Old Nov 9, 2005 | 10:42 PM
JonnyBravo's Avatar
JonnyBravo
good luck with the final mapping then mate,
a slightly more serious spec than I can afford to go for now, think I'll just stick to the 803's and just enjoy sticking the arse out everywhere till I can afford to change for a better spec
cheers for the info though
Old Nov 9, 2005 | 10:47 PM
Damo V's Avatar
Damo V
I was more than happy with my 803 setup... in my comparatively lard arsed car... till it melted
Old Nov 9, 2005 | 10:59 PM
Redkop's Avatar
Redkop
Steve Scott did mine - L8, light blues, standard cams, T34 with .55 housing, air injectors running approx 375-380bhp, 1.9psi boost and has been 100% reliable for 2 and a half years.
Old Nov 10, 2005 | 12:06 AM
Lambchop's Avatar
Lambchop
PF Idiot Sniper
1.9psi love? wow!
Old Nov 10, 2005 | 11:22 AM
Paul Eggleton
Don't know yet Damo. I haven't decided if the whole thing is coming apart yet or wether it will just be the top end. Bottom end still seems sound at 87K.
Old Nov 10, 2005 | 11:32 AM
DaveEscos's Avatar
DaveEscos
damo? you downsized the .63 to a .48??
Old Nov 10, 2005 | 11:40 AM
Redkop's Avatar
Redkop
1.9psi love? wow!
Amended especially for you Chop... 1.9 bar or to be precise holds 27.9psi and peaks at about 30-31psi
Music & Car Audio Chat
Sep 3, 2017 01:24 PM
Nov 1, 2015 06:53 PM
timsrs
22
Sep 24, 2015 08:14 PM
Rsmat
42
Sep 1, 2015 09:39 PM
Sheepdisease
Aug 30, 2015 09:11 PM
