escos battery fusable links
Old Nov 8, 2005 | 06:41 PM
Dave Henshall's Avatar
Dave Henshall
Default escos battery fusable links
i know now that the yellow and black ones on the extra box bolted to the battery pos terminal dont pull out as they are held in by the bolts undernearth, but in findnig this out the hard way ive fooked one of the yellow ones up - (60amp) there are 2 red(which do pull out), 2 yellow and a black one.
could someone just confirm that this is the correct finis code as the pic is a mile out on microcat
6509686 - £2.30
cheers, dave
Old Nov 9, 2005 | 10:05 AM
Dave Henshall
just phoned ford, the actual price is £5.28 inc vat,
and its a non stock item - when it wouldnt come out with a pait of mole grips, i should have thought it wasn't supposed to come out
Old Nov 9, 2005 | 10:17 AM
Stu @ M Developments's Avatar
PassionFords Creator
Been here, done this, broke em too
Take the fusebox OFF the battery, and you will find the tw@s bolted in at the BACK as well
Old Nov 9, 2005 | 12:59 PM
Dave Henshall
i even took them all off when i cleaned all the terminals up last year and found tehy wer bolted in , doh!
Nov 1, 2015 06:53 PM
gcfcos
59
Oct 6, 2015 05:04 PM
Fil
Sep 30, 2015 12:08 PM
