12PSI - WHY?
Old Nov 8, 2005 | 12:58 AM
vroooom ptssssh's Avatar
vroooom ptssssh
It Wasnt Me!
Default 12PSI - WHY?
Howdy,
I got my rs turbo set up with std boost/ignition timing etc
It boosted to 7psi, and ran perfect!
few months later, i noticed it boosted to 12psi? it did hesitate if you put your foot to the floor, but if you do it slowly it boosted fine, no hesitation probs.
Took it out not long ago, was fine, still boosting to 12psi, but no miss-fire?
it kinda goes like:
d-d-d-d-*pop*(from exhaust)
new fuel tank wasnt exactly mint inside, plug leads are shite, new plugs, dizzy im not sure what nick it is in.
Just wondering really what reason it would suddenly decide to hit 12psi? ive no bleed valve, piped up via amal valve, im sure it has a turbosystems chip, any ideas? and am i right in thinking it will be fine (ign timing/fueling) if it hits 12psi and IS infact chipped? (didnt hit overboost so i assume it is?)
Old Nov 8, 2005 | 08:54 AM
T28 RST's Avatar
T28 RST
Ok then
Default Re: 12PSI - WHY?
Howdy,
If its doing the d-d-d-d-*pop* then you are hitting the boost limit which means the ECU isnt chipped otherwise it would keep pulling instead of hitting the boost limiter
Old Nov 8, 2005 | 09:43 AM
adamS2RST's Avatar
adamS2RST
dddd pop
Old Nov 8, 2005 | 01:56 PM
vroooom ptssssh
It Wasnt Me!
Davie, it boosts to 12psi no bother if you dont bring the boost in hard is which i dont understand
Ive got a feeling it's the plug leads and it's gotta be chipped if it has a -31 unless someones swapped ECU's
It doesnt feellike boost cut, it's like a missfire
AND WHY IS IT SUDFDENLY HITING 12 PSI
Old Nov 8, 2005 | 02:59 PM
adamS2RST's Avatar
adamS2RST
Has somone been fiddling with the actuator
Old Nov 8, 2005 | 03:03 PM
vroooom ptssssh
It Wasnt Me!
Nope, not that i know of!! ive not touched the thing
Old Nov 8, 2005 | 04:30 PM
addiction's Avatar
addiction
it doesnt have to be chipped to have a -31 actuator
Old Nov 8, 2005 | 05:32 PM
vroooom ptssssh
It Wasnt Me!
addiction, yes i know. but it's likely to be if it has a -31 (unless as i said someone has wapped ECU's)
Why else would you fit a -31? to run more boost. . . and what do you need to do that? a chip
Old Nov 8, 2005 | 09:38 PM
addiction's Avatar
addiction
it would have benefit's on a car that was not chipped.
i was only saying that just because it has -31,do'esnt mean it's gonna definately be chipped. dont have a cow man
Old Nov 8, 2005 | 11:10 PM
vroooom ptssssh
It Wasnt Me!
Mooo
but you really only fit one when you fit a chip that's all i was meaning, no need if it aint chipped, so wouldnt be that beneficial
still dont understand why it hits 12psi
Old Nov 9, 2005 | 08:51 PM
vroooom ptssssh
It Wasnt Me!
Come on give me some help
Old Nov 9, 2005 | 09:18 PM
bassboy's Avatar
bassboy
have you recently been over the vacuum pipes etc recently? i noticed mine would sometimes peak at 8-9psi even though its ran 7normally...however it stopped doing it and when i went over the engine tightening all the vacuum and boost hoses...im now peaking at 9.5-10psi where Ahmed originally set it up at
and it may be down to the weather..this cold damp weather means slight more boost
bassboy
Old Nov 9, 2005 | 09:29 PM
DazC's Avatar
DazC
Dave, I think that the weather conditions sometimes has an effect on pressures. Mine runs 1 bar (14psi) held but has been known to hit 1.3 (19psi) when the weather is cool/moist!
Old Nov 9, 2005 | 11:50 PM
vroooom ptssssh
It Wasnt Me!
I thought that Daz, whenever it's been out it has been cold but didnt think it would rise so much, could be right tho, would coincide anyway!
what effect would it have if the anal valve packed up?
Old Nov 10, 2005 | 12:52 AM
rsrob's Avatar
rsrob
amel valve is proberly goosed as it acts as a restrictor for the boost so if it isnt working it will boost to what ever the actuator rod is set at
take off the actuator rod and unscrew it 1 full turn which will then be aprox 2psi less
dont forget if your running more boost it will need more fuel and you said it was set up on 8 psi, so if you want to keep the new boost limit you will need to get it set up again
Old Nov 10, 2005 | 01:53 AM
vroooom ptssssh
It Wasnt Me!
rsrob, cheers mate, will the fueling deffo need done even if it's chipped?
Maybe this is the cause of the ddd *pop*
Old Nov 10, 2005 | 02:31 PM
Combi_Chris's Avatar
Combi_Chris
mine goes blub blub blub pop , but its the water temp senor hehehe
Old Nov 10, 2005 | 02:33 PM
rsrob's Avatar
rsrob
oh hello chris wondered where you might pop up again
Old Nov 10, 2005 | 03:27 PM
vroooom ptssssh
It Wasnt Me!
Also thought my thermo time switch was fooked cos it's a cock to start, bu that's another job for later
how can you test a thermo time switch?
Old Nov 10, 2005 | 04:03 PM
Combi_Chris
i have no idea how to respond, i dont remember you rob from anywhere
Old Nov 10, 2005 | 04:24 PM
T28 RST's Avatar
T28 RST
Ok then
LOL
Remember when you got banned from RS Turbo mania for constantly boring people and posting shite
Remember now
Old Nov 10, 2005 | 04:27 PM
Combi_Chris
yes , i remeber what i like about that forum now , but i prefer passion ford, the people know lots more and are not too childish
Old Nov 10, 2005 | 04:30 PM
T28 RST's Avatar
T28 RST
Ok then
Who was the childish one that got banned for being an arse that didnt have a clue about anything remotley connected to an RS Turbo
Funny how you just remembered about it when i asked you but when rob asked you acted dumb as usual
Old Nov 10, 2005 | 04:32 PM
Combi_Chris
t28 have you had a bad day ? please dont try to intimidate me into an argument ok...im getting on ok on this forum , thanks .
Old Nov 10, 2005 | 04:37 PM
T28 RST's Avatar
T28 RST
Ok then
As long as you keep your head down and dont wind everyone up you should got on ok
Old Nov 10, 2005 | 04:39 PM
rsrob's Avatar
rsrob
thought you would remember
ok back to the topic sorry vroooom ptssssh for going off topic
Old Nov 10, 2005 | 05:52 PM
vroooom ptssssh
It Wasnt Me!
dont mind me
f'king rs turbos
Fiecos Dan
Nov 6, 2006 10:41 PM
vroooom ptssssh
Feb 11, 2006 01:24 PM
wrcwrc
Dec 27, 2005 06:23 PM
rs shawn
Jun 24, 2005 11:51 AM
PAUL V
25
Nov 25, 2004 06:06 PM
