2wd and 4x4 cosworth differences
Old Nov 5, 2005 | 08:25 AM
jrstcos's Avatar
jrstcos
Default 2wd and 4x4 cosworth differences
Hi, can some one tell me the diferences between 2wd and 4x4 engines???
i know 2wd block is 205 and 4x4 is 200 but are the oil pumps, conrods, pistons etc different and will each item fit on either car?
Old Nov 5, 2005 | 01:03 PM
jrstcos's Avatar
jrstcos
anyone?????
Old Nov 5, 2005 | 02:22 PM
wimwerf's Avatar
wimwerf
different thermostat, cylinder head, slightly different pistons (if im not wrong), different sump, different pulleys (not the cam pulleys)....there should be more i think....
Old Nov 5, 2005 | 03:29 PM
jrstcos's Avatar
jrstcos
i was on about the internal stuff as outside stuff is obvious to see.
Old Nov 5, 2005 | 03:31 PM
GARETH T's Avatar
GARETH T
differnent oil pump
different cracks (from pully mount longer on 4x4 i think)
same rods
different pistons
MARKYMARKONE
Aug 20, 2015 12:55 PM
Aug 14, 2015 07:29 AM
adam151082
Aug 11, 2015 04:50 PM
Old ford
Jul 31, 2015 06:50 AM
