Hot Start help!
When ive been driving my ERST and its got up to temp, if i turn it off and try to start it again it is a real pain to get going again! has anyone had this problem before!
The starter motor is brand new and so is the dizzy , the cap and rotor arm they have only done 300 miles as im still running new motor in. wondered if it could be one of the sensors or something like that?
mine does the same, got no shield either, will i get away with out getting a new starter if i jus get the heat shield? or will the damage have been done and will the starter do the same even when a little bit hot?
