cossie 2wd parts...
Ecu and loom
intercooler
radiator and fans
all the hoses
all the fuel hoses
power steer tank
power steer hoses
complete fuel pump,filter&bracket unit with loom
inlet maifold (only the inner part,where sits the injectors)
ignition module
ignition coil
manifold absolute pressor sensor (MAP)
amal valve
turbo oil feed pipe (&return)
turbo water feed pipe (&return)
intercooler
radiator and fans
all the hoses
all the fuel hoses
power steer tank
power steer hoses
ignition module
ignition coil
amal valve
dojj
28
Sep 11, 2015 10:00 PM
