how much for a super chip
Ian,
I've got one for sale.
I'ts the latest spec Ahmed Bayjou (Pectel) chip on a "baby board" (printed circuit board) that mounts within your ECU and connects to the main PCB board by the attached ribbon cable Ł 250.00 + P & P.........
I will post up the Interpro rolling road graph later - SUPERB low down torque, peaking at 3,500 RPM !!!
It made 338 ft/lbs torque AND 338 BHP on just 18 PSI boost (standard head gasket). Only other mods to the car were Bosch greens, 3 BAR and fuel pump (Walbro)....
Dave Griffiths at Interpro said that if I changed the h/gasket to Group A then it could run 22 - 24 PSI boost with this chip no problem
mark94
Ford Mondeo Including ST
Oct 10, 2023 06:52 PM
