various cossie & rs turbo parts, updated with pics
having a bit of a clear out in the shed & cupboard at home, found loads of stuff i have hoarded over the years!!!!! seeing as we don't have an escort turbo, 3 door or saff cossie anymore these parts are no longer much use to me, plus the space will be handy, as will the cash towards the escos rebuild
was going to put pictures up, but can't be bothered at the moment
anyway, i have a list of various parts, some are new, all second hand parts are as described, here go's, (click link fo pic)
escort rs turbo cold start valve, brand new & boxed £50
saff cosworth fuel cap, later style twist fit one, brand new £5
http://img.photobucket.com/albums/v2...afffuelcap.jpg
fiesta mk3 (turbo, xr2i etc) boot lock, brand new with 2 keys £10
http://img.photobucket.com/albums/v2...e/bootlock.jpg
genuine ford '909' group a clutch release bearings £20 each
'92 spec saff cossie 'sharktooth' or 'snowflake' wheel centre caps £10 pair
4x4 saff cosworth rev counter, brand new boxed £50
http://img.photobucket.com/albums/v2...ssie/tacho.jpg
4x4 cossie or big turbo escos throttle body, brand new boxed £75
as above but with tps & iscv, also brand new boxed £250ono
cam pulley, brand new, marked 'LA' finnis code 6087 222 £5
http://img.photobucket.com/albums/v2...sie/pulley.jpg
3 door cossie heater blower switch, brand new boxed £15
http://img.photobucket.com/albums/v2...owerswitch.jpg
3 bar map sensor, second hand, works fine £50 SOLD
saff cossie heater resistor, new & boxed £10
4x4 saff of big turbo escos distributor cap, new boxed & genuine, £20
fiesta turbo arm rest/door pull in grey, n/s, brand new, small scratch hence £5
http://img.photobucket.com/albums/v2...fezarmrest.jpg
saff clear indicators, pair of, good condition £7.50 SOLD
S2 n/s clear indicator, bit tatty £2
ford plastic battery covers, to fit smaller batterys, £5 each
http://img.photobucket.com/albums/v2...tterycover.jpg
S2 metering head, fuel flap & pressure reg, worked when taken off car but been sat around for a few years, not sure if it will still work properly, hence £10
http://img.photobucket.com/albums/v2...ie/s2mhead.jpg
S2 inlet manifold with tps, aux air sensor, throttle body etc, had plenum polished but has now gone dull (but still smooth) £15
http://img.photobucket.com/albums/v2...ie/s2inlet.jpg
'88 spec seat parts, l/h bolster cover, centre back section & foam, centre lower section & foam, £10
saff front window switch coloum & both rear switches £5
http://img.photobucket.com/albums/v2...ffswitches.jpg
saff electric mirrors (covers painted magenta) with glass £20 pair
http://img.photobucket.com/albums/v2...affmirrors.jpg
S2 n/s head lamp, carrello, silver finish, new & boxed £15
http://img.photobucket.com/albums/v2...s2hlampnew.jpg
saff head lamp glasses, new boxed genuine ford £25 pair SOLD
saff head lamp glasses, second hand but ok, £5 pair
http://img.photobucket.com/albums/v2...e/saglassh.jpg
S2 head lamp covers, gen ford new & boxed £50
http://img.photobucket.com/albums/v2...lampcovers.jpg
S2 fuel hose, rear of pump to tank, new genuine ford £5
http://img.photobucket.com/albums/v2...s2fuelhose.jpg
4x4 saff cossie high pressure power steering hose, new genuine £40
http://img.photobucket.com/albums/v2...saffpshose.jpg
3 door cosworth tailgate decal, new genuine & boxed (RARE) offers
3 door cosworth tailgate lock solnoide, genuine, new & boxed £20
http://img.photobucket.com/albums/v2.../solenoide.jpg
escort cossie n/s hockey stick, genuine, still in ford wrapper £70
http://img.photobucket.com/albums/v2...scoshockey.jpg
2wd cosworth brake pads, genuine ford, new & boxed £30 SOLD
S1 genuine o/s side decal, new & boxed, missing the part for the wing, £SOLD
pair of 3 door rear lamps & gaskets, all brand new genuine ford £150 SOLD
ngk racing 9 iridium plugs (set of 4) new & boxed £50 SOLD
3 door o/s headlamp glass, gen ford, new & boxed £20
saff headlamp covers, were on car for 2 weeks, back in origional wrappers & box, £30
3 door rear panel, gen ford, new £SOLD
3 door rear quarter, gen ford, new £150 SOLD
S2 fuel computer, new & boxed £20 (comes with s/h fuel flow sensorSOLD
theres some more bits, if i get the time to root through them i will add them, thanks for looking
also found,
italvolante steering wheel, cossie or escort turbo fitment, mint, £75
http://img.photobucket.com/albums/v2...alvolante2.jpg
fiesta turbo bonnet, brand new but damaged, could possibly repair or just use the vent recesses £10
powerflex wishbone bushes for mk 3 fiesta (rs turbo, xr2i ect) or mk 5 escort, brand new £40
http://img.photobucket.com/albums/v2...frstbushes.jpg
rs turbo S1/2 ramair induction kit, used, ok £15
http://img.photobucket.com/albums/v2.../ramairrst.jpg
boyracer exhaust, anodised red can with polished silver 4" tailpipe with heat effect, came off a S2 escort £30
mac audio 12" sub, 300w, brand new £50
saff cossie fog lamp bezels, new £25
http://img.photobucket.com/albums/v2...saffbezels.jpg
2wd cossie cooler, ok £25
http://img.photobucket.com/albums/v2...ER/cooler2.jpg
S2 rs turbo/xr3i ABS belts, 1 early type, 1 late type £5 each
escort RS Turbo amal valve, new & boxed, £25
http://img.photobucket.com/albums/v2...ossie/amal.jpg
also found,
2wd cosworth starter motor, brand new genuine Ford £60
cosworth cam cover with breather port welded in, freshly painted in green (like '92 spec saff) £65 SOLD
http://img.photobucket.com/albums/v2...e/camcover.jpg
L8 ecu, green top, something wrong with the babyboard in it, but runs fine on another b/b/ i tried in it, hence £100 SOLD
RS Turbo fan switch, new gen ford £5
http://img.photobucket.com/albums/v2.../fanswitch.jpg
2wd outer rear c.v. stub, brand new £20
http://img.photobucket.com/albums/v2...ossie/stub.jpg
RS Turbo rear wheel bearing, new gen ford £10
bailey dump valve, dv24 £20 SOLD
saff wiper switch, new gen ford £15
Fiesta turbo big brake kit, hi-spec, 280mm disks & caliper spacers, brand new £125
http://img.photobucket.com/albums/v2.../285mmconv.jpg
2wd cosworth T5 5th gear, brand new gen Ford (& bearing) £60
http://img.photobucket.com/albums/v2...ie/5thgear.jpg
S2 fuel pump relay, new gen £15
http://img.photobucket.com/albums/v2...ie/s2relay.jpg
3 door grille seal, brand new £15 each
http://img.photobucket.com/albums/v2...grilleseal.jpg
escort cosworth radio, cd player, amp & lead £100 ono
mk1, mk2 escort or mk 1 capri lower arms, new genuine ford £75 pair
escos/3 door fog lamps, new gen ford £50 pair
http://img.photobucket.com/albums/v2...e/foglamps.jpg
RS2002 mk5/6 fuel rail with injectors, new gen ford £80
http://img.photobucket.com/albums/v2...e/furlrail.jpg
mk5 escort headlamp protectors, new £20 SOLD
mk4 fiesta headlamp protectors, new gen ford £20
mk3 fiesta headlamp protectors, new £25
also found,
also found,
how much for just iscv inc p+p, is it brand new?
are those the plugs you sold to me 1 1/2 years ago, but didn't reply to my pm's???
i have a seperate iscv, i got it for my 4x4 but that wasn't the problem, so its been on the car for about 10 mins £100 posted.
Passionate about fords
hi there mate, interested in the escort rs turbo amal valve, i gather as its new its in perfect condition/working order..........is that £25 posted ???? if so ill take it buddy.
thanx mate
dave
tel:- 07747708686
thanx mate
dave
tel:- 07747708686
ok mate ya got a deal
.........can it be sent recorded so its insured ????. how do you want the money mate, via paypal is the quickest way ????.
thanx mate
dave.
.........can it be sent recorded so its insured ????. how do you want the money mate, via paypal is the quickest way ????.thanx mate
dave.
Originally Posted by SWITCHBLADE
HEY BUD, IT WAS THE NEW ESCORT RS TURBO AMAL VALVE
THANX
DAVE.
.THANX
DAVE.
don't do paypal but you can send a cheque or cash.
Originally Posted by alan rainbow
guzz mate the t5 5th gear is not from a t5 box mate it looks like a mt75 one
cheers.
ok buddy £27 fines,
ill send you a cheque mate, if you wanna send me ya details for who to make the cheque payable to and where to send it ill get it into the post for you straight away, email is :- EKZAVIER@HOTMAIL.COM.
cheers mate
dave
cheers mate
dave
butterfly, i don't have a paypal account, sorry. can do cheque or cash
speedy, i don't know anyone with standard escos lights to try them on....
but i'll see if i can find out.
Originally Posted by butterfly
COME ON GUZZLER,
You going to send your address so we can buy the light's?.
Char.
Char.
i'll do it now
i still have the headlight glasses, there £25 + postage, thats cheap, price a set up at fords
but do you know John at minimec???
i could get them dropped off to him to save the postage
I'd like to buy the wd starterengine. Will of course pay for the P&P.
Could you please find out how much it would cost to Sweden?
And give me your banks BIC and IBAN, so that I can transfer the money.
Kind regards Andreas
Manet postage would be about £60
BIG TONY RS PM replied to
cossiemen I have taken a deposit on them, i'll chase the fella & make sure he still wants them.
Billy_RS
16
Oct 11, 2025 09:41 PM
muz
Aug 16, 2015 12:57 PM
155lee
Aug 14, 2015 11:21 AM
