took my d/v of, i need louder flutter, how?
Old Oct 30, 2005 | 12:22 PM
AJC's Avatar
AJC
Default took my d/v of, i need louder flutter, how?
took my dump valve of yesterday, i like the flutter but its not very loud, does any one know best way to get it fluttering louder,
cheers peeps
Old Oct 30, 2005 | 12:25 PM
swerv's Avatar
swerv
cossie mgmt
adamS2RST's Avatar
adamS2RST
What car is it? Your S1? If it's still on MFI it aint going to do it that loud to begin with...
Old Oct 30, 2005 | 12:31 PM
AJC's Avatar
AJC
yes, the s1
i aint changin management, yoo much hassle
im stil on mfi
Old Oct 30, 2005 | 12:34 PM
adamS2RST's Avatar
adamS2RST
Originally Posted by Series1AJC
yes, the s1
Then you wont get much "flutter" as you mention because its running the standard management, as mentioned you will with cossie, fiesta turbo efi or another aftermarket system which ditched the fuel metering unit etc
Old Oct 30, 2005 | 12:35 PM
AJC's Avatar
AJC
i have a full efi set up in my garage outside
Old Oct 30, 2005 | 12:37 PM
mantamark's Avatar
mantamark
Sorry to butt in, but why do people ditch the std setup & go for efi?
Is it hard to do? worth doing? what bits are required?
I am also thinking of ditching the dv, have been told to fit a cone filter, instead of panel filter, as will make the flutter louder?
Cheers, and sorry for jacking the thread
Old Oct 30, 2005 | 12:38 PM
AJC's Avatar
AJC
efi supposed to be better, more reliable etc
Old Oct 30, 2005 | 01:29 PM
mantamark's Avatar
mantamark
Cool, will look into it, cheers mate.
You have made me decide to remove my dv, but i dont know what to do with the little vaccum pipe thats on the top of the dv, wheres it go?
Old Oct 30, 2005 | 01:55 PM
DazC's Avatar
DazC
Block the vac pipe off....
The metering unit muffles the chattering sound so without ditching the MFI set up, it will always be quiet.
Old Oct 30, 2005 | 01:57 PM
AJC's Avatar
AJC
cheers daz
Old Oct 30, 2005 | 02:17 PM
DazC's Avatar
DazC
Sorry mate!
More money I know. Save it for the big valve head....
Have you spoke to Stu to see how much his mate will do it for?
Old Oct 30, 2005 | 04:11 PM
SamERST's Avatar
SamERST
Try different cone filters mine chattered like a cunt with my old skool pipercross cone, now ive got a ram air and the chatter isint that loud
...also k&ns are shite for what your after
Old Oct 30, 2005 | 04:14 PM
adamS2RST's Avatar
adamS2RST
It's still not going to sound as loud as any aftermarket management tho!
Old Oct 30, 2005 | 05:20 PM
AJC's Avatar
AJC
Sorry mate!
lol,
no i aint spoke to him about it
will do this week i think
Old Oct 31, 2005 | 08:49 AM
zippyobrien's Avatar
zippyobrien
im on mfi and my chatter is much louder than any dumpvalve (you can hear it if driving along in a car next to it even on the motor way).
ive got an old school piper cross sponge filter (its bloody huge, about the same size as a size 5 football)
the amount of boost your running also affect the amount of chatter, this is because the turbo will stall harder if your runing more boost, and it is the stalling wich cause the sound.
also, running a fmic should make it louder due to making the turbo less restrictive.
im running a stage 3 turbo, 1.4 bar and a race gate actuator (the charateristics of the actuator also affects turbo stall)
obviousely the metering head is going to restrict it slightly but switching to after market management isnt going to make that much difference
Old Oct 31, 2005 | 10:08 AM
twinkle_2k86's Avatar
twinkle_2k86
oh just what i have been wondering latey for my S2 turbo, i want to ditch the DV for chatter, so an old school piperX filter i need to get then and see what happens then.
Old Oct 31, 2005 | 10:43 AM
adamS2RST's Avatar
adamS2RST
OK
Old Oct 31, 2005 | 10:45 AM
SamERST's Avatar
SamERST
Yep and the bigger the better, the one i had was the one with the sort of cup shape at the top
Old Oct 31, 2005 | 10:46 AM
SamERST's Avatar
SamERST
Yep i agree im running the same sort of boost and spec and mine chatters nearly as loud as my old bailey dv.
Old Oct 31, 2005 | 01:32 PM
adamS2RST's Avatar
adamS2RST
Old Oct 31, 2005 | 06:42 PM
AJC's Avatar
AJC
Old Nov 2, 2005 | 03:35 PM
s2 ben's Avatar
s2 ben
ive had 2 s2s and they both wont chatter cone or panel filter it dnt work is they another trick you have 2 do
Old Nov 2, 2005 | 04:06 PM
adamS2RST's Avatar
adamS2RST
No, it simply WONT work as stated above, you may get minimal chatter but nothing like you do on EFI / Cossie management, and if you do you have a serious air leak! as mentioned its the metering head that muffles out the sound
Old Nov 2, 2005 | 04:14 PM
sufsRS's Avatar
sufsRS
first things first its proven that the standard box is best performance wise wot is the point in running more boost and adding a fmic if your sucking in hot air? secondly you cant get a "size 5" cone in an rst as their is no room lastly an aftermarket management system will make all the difference, with the mfi system your not meant to get chatter if you ar then theirs you need a new fuel metering unit
Old Nov 2, 2005 | 09:31 PM
AKRS1's Avatar
AKRS1
im running 18psi on my s2 and i get just minor fluttering no matter how hard i boost up and change gear. EFI is the best way to go as you can run more power too
Old Nov 2, 2005 | 10:17 PM
scort's Avatar
scort
http://www.rsbible.co.uk/vids/escortchatter.htm
Running 12psi,
EFi is the only way to get it to chatter properly.
Steve
Old Nov 2, 2005 | 10:23 PM
GrimmeRS2K's Avatar
GrimmeRS2K
as said if ur fluttering on mfi, your metering unit is fucked!. EFI always for flutter
Old Nov 2, 2005 | 10:25 PM
Šhatter Box's Avatar
Šhatter Box
well i got the best chatter so there
Old Nov 3, 2005 | 06:48 AM
adamS2RST's Avatar
adamS2RST
Old Nov 3, 2005 | 06:36 PM
S2_Kev's Avatar
S2_Kev
mine chatters nicely with 18psi, -34 actuator and K&N. the again its more of a ccchhhhhhhuuuuuummmmm noise
RSCossieGaz
14
Apr 8, 2005 10:41 PM
vroooom ptssssh
Aug 21, 2004 01:56 PM
CabrioTurbo
11
Aug 9, 2004 02:37 PM
Windle
Jul 6, 2004 08:24 AM
Thrush
Jul 5, 2004 07:51 AM
