I section rods & H section rods for a cossy
Old Oct 28, 2005 | 03:37 PM
abdr500's Avatar
abdr500
Default I section rods & H section rods for a cossy
whats so better about i beam rods over h beam rods all ways thought that h was better stronger .whats your views thanks
Old Oct 28, 2005 | 03:52 PM
GARETH T's Avatar
GARETH T
my views are there is nothing wrong with standard unless you wannna change the geometry of the engine
Old Oct 28, 2005 | 03:55 PM
Mike Rainbird's Avatar
Mike Rainbird
Caraholic
What he said .
Old Oct 28, 2005 | 04:01 PM
pee vee's Avatar
pee vee
while this is up here.
Are the standard cossie Rods the weak point of the engine?
(or least strong point)
if they are not, what is?
thanks!
Old Oct 28, 2005 | 04:04 PM
Mike Rainbird
Caraholic
thanks!
Nope, standard pistons are the weak link. Cosworth or other forged ones are required for above 500bhp.
Old Oct 28, 2005 | 04:08 PM
Porkie's Avatar
Porkie
As Gareth and Mike Standard rods are a little heavy to be using much over 8200 rpm but are as strong as old boots
Old Oct 28, 2005 | 04:09 PM
pee vee's Avatar
pee vee
brillient thanks Mike!
they made the YB quite well in that respect then!?
Old Oct 28, 2005 | 04:19 PM
Stavros's Avatar
Stavros
DEYTUKURJERBS
The YB was made as it was for homologation reasons, GrpA rules at time stated they had to use standard crank and rods, so they had to be able to take 500bhp+ for a full race with no probs, so strong as fuck
Same as why standard RB26 crank and rods are silly strong.
Old Oct 28, 2005 | 04:21 PM
Kevin Sharp's Avatar
Kevin Sharp
my standard rods and crank have been fine running over 600bhp
however they have now been fired as someting else is getting their job
Old Oct 28, 2005 | 06:55 PM
Ginge !'s Avatar
Ginge !
just finding my feet
my cossie bent 3 rods when i stripped the engine down
does that mean i was just unlucky and should stop dropping it to second for quick braking and byuy some bigger brakes then
Old Oct 28, 2005 | 08:01 PM
xr4x4rs's Avatar
xr4x4rs
ive always been told if i wanted to go for 500 or above i need stell crank and rods
so what will a yb crank and rods handle i.e
lightened and balanced
knife edged
tungstun coated
also rods polished and stressed relievd
balanced etc
will they be up to the job for 450 reliable
im using cosworth forged grp a pistons 7.2.1 c/r
Old Oct 28, 2005 | 08:02 PM
Kevin Sharp
all cossie crank and rods are steel
Old Oct 28, 2005 | 08:04 PM
Kevin Sharp
oh and mine have been tested to around 675bhp... standard
Old Oct 28, 2005 | 08:06 PM
xr4x4rs's Avatar
xr4x4rs
well thats just reasured me then
thanks mate
Kevin Sharp
Old Oct 28, 2005 | 08:20 PM
Ginge !'s Avatar
Ginge !
kevin forgot to mention there fooking heavy
people only think the cossie rods aint as good as they aint finished all blingy like the farndon jobys
Old Oct 29, 2005 | 01:05 AM
Stavros's Avatar
Stavros
DEYTUKURJERBS
det.
piston in cyl moving up while det tries to push the thing down equals bent rods.
esp as in cyl pressure in det is massivley more than normal
Old Oct 29, 2005 | 09:34 AM
DazC's Avatar
DazC
Incorrect ignition advance/retard can bend rods!
Old Oct 29, 2005 | 02:56 PM
Porkie's Avatar
Porkie
Thats because I had already said it. Kev actually reads and thinks before he posts
Old Oct 29, 2005 | 02:59 PM
POPEYE's Avatar
POPEYE
FAIRY CAKE
where as your just ginger
Old Oct 29, 2005 | 03:01 PM
Ginge !'s Avatar
Ginge !
mine deffo aint det, theres NO det on my pistons or head at all !!!!, thats what i cheacked
gcfcos
59
Oct 6, 2015 05:04 PM
Brickhouse
14
Oct 3, 2015 07:28 PM
XR4
Ford XR Range
Oct 1, 2015 12:46 PM
PRO-LINE MOTORSPORT
Sep 28, 2015 09:54 PM
