Hessitant YB when coming off idle
Old Oct 28, 2005 | 08:35 AM
Ratty's Avatar
Ratty
Default Hessitant YB when coming off idle
My idle takes a little while to settle down and I assume this is due to the iscv but also when you come off idle slowly the engine hessitates slightly
If you plant the throttle its fine, now is this due to my over fueling problem (see here) or is my TPS on the way out as well
Engine is stage 1, with coil pack and 071's
Old Oct 28, 2005 | 08:59 AM
Jimboxr4x4's Avatar
Jimboxr4x4
Sounds like it could be a prob with the TPS. There is a way to test it. The voltage should go between 0.8 and 4.5 volts or similar and should be a regular increase with throttle. From what I understand the TPS is just a variable resistor and I think the tracks can get worn. Quite a few posts on Interford about it.
Old Oct 28, 2005 | 09:00 AM
Ryan's Avatar
Ryan
as Said either TPS, ISCV or fueling issue
Ryan's Avatar
Ryan
oh PS, glad to see you got the old girl running
Old Oct 28, 2005 | 10:18 AM
Ratty's Avatar
Ratty
Cheers Ryan
I will get some upto date pics up this weekend as I've had to replace the cams etc but finally it looks like some light is at the end of the tunnel
Only a few little jobs left to do now before I take it to Stu to get setup
Rev Counter (may leave this for Stu)
Fueling
TPS
ISCV
15
Oct 7, 2015 03:43 PM
RSmark84
Sep 13, 2015 01:29 PM
Marino
Sep 12, 2015 11:10 AM
natehall
Ford Focus (All Models)
Sep 8, 2015 05:13 AM
routemaster
Sep 7, 2015 05:27 PM
