Esc Cos Up Rated Pump Question
Old Oct 26, 2005 | 11:14 PM
Ollie's Avatar
Ollie
Default Esc Cos Up Rated Pump Question
Could any 1 on here tell me if a Bosch 0580254023 is the correct up rated pump for an escort cos , and if so is there some sort of fitting kit needed to go with it . The reason being if it is correct it doesnt look like it will fit as a direct replacement for the OE pump . Cheers
Old Oct 26, 2005 | 11:15 PM
Billabong's Avatar
Billabong
There are two suitable in tank Bosch pumps I think (sure 023 is one of them), and they both need a fitting kit, which Mike R etc. can supply if required.
Old Oct 26, 2005 | 11:16 PM
Ollie's Avatar
Ollie
Thanks for that info m8
Old Oct 27, 2005 | 07:01 AM
DaveEscos's Avatar
DaveEscos
the 023 doesnt look anything like the std pump, but it fits witht he right kit..
just use a hose from the pump to the union with jubilee clips and wire as per normal.
pump jubilee clips to the sender pole/mast
Old Oct 27, 2005 | 07:06 AM
Disabled Account's Avatar
Disabled Account
Ollie, I have a fitting kit - brand new! It was supplied by Mike R....
Bought it to fit to Cossieracers Es Cos but when we dropped the tank it already had one fitted
Doug.
jonfoc
16
Sep 11, 2018 05:35 PM
Music & Car Audio Chat
Sep 3, 2017 01:24 PM
155lee
Oct 27, 2015 04:55 AM
BRAMMER
15
Sep 14, 2015 08:52 PM
andrewmctiernan
Sep 8, 2015 03:05 PM
