Who makes the best injectors for a setup in WRC plenum?
Old Oct 26, 2005 | 10:58 PM
GT2's Avatar
GT2
Default Who makes the best injectors for a setup in WRC plenum?
What injectors will be the best to use in an WRC plenum? siamese ports?
Spray pattern wise. At about 6-800 cc pr injector?
Old Oct 26, 2005 | 11:00 PM
capri-rs's Avatar
capri-rs
ask mr jens han veit velll
Old Oct 27, 2005 | 07:39 AM
Mike Rainbird's Avatar
Mike Rainbird
Caraholic
Bosch ones .
Old Oct 27, 2005 | 08:17 AM
GT2's Avatar
GT2
Which ones then?
Old Oct 27, 2005 | 08:19 AM
Mike Rainbird
Caraholic
Depends what ECU you are running and what power level you want . I'm runnning eight 803s in mine, but this limits power to an absolute maximum of 580bhp.
Old Oct 27, 2005 | 09:44 AM
GT2's Avatar
GT2
Aftermarket ECU and around 650 hp.
Old Oct 27, 2005 | 09:49 AM
Mike Rainbird
Caraholic
Eight greys or if the aftermarket ECU can cope with it, four standard injectors for low speed running and phase in four 1000cc for the on boost running.
Old Oct 27, 2005 | 09:53 AM
DaveEscos's Avatar
DaveEscos
oh shut up mike you hom.. what do YOU know!
Old Oct 27, 2005 | 10:01 AM
Mike Rainbird
Caraholic
Dave,
STFU you c*unt and post some pictures of your car with the bumper on . Actually, don't bother, as all I have to do is look at the car you copied . One day, you might actually have an ORIGINAL idea .
GT2's Avatar
GT2
Which Bosch injectors are 1000cc?
Old Oct 27, 2005 | 10:03 AM
Mike Rainbird
Caraholic
Well you can use some MSD hose-pipe ones if your ECU can run different types - one set for good emissions and low speed running, and the hose-pipes to add the necessary fuel for the on boost running .
However, Bosch do do so close to that figure anyway with a reasonable spray pattern .
Old Oct 27, 2005 | 10:04 AM
DaveEscos's Avatar
DaveEscos
Mine looks better then that imo
get yourt bumchum Chris FLint to send me back my fucking grille too!
Old Oct 27, 2005 | 10:07 AM
Mike Rainbird
Caraholic
Pictures - or STFU .
Old Oct 27, 2005 | 10:08 AM
DaveEscos's Avatar
DaveEscos
might go and do a location shoot today actually ...... maybee a few pectel monitor install pics
maybee NOT!
Old Oct 27, 2005 | 10:09 AM
Mike Rainbird
Caraholic
I best make sure the grill gets "lost" then. Pictures, or the grill gets it .
Old Oct 27, 2005 | 11:35 AM
essexrsturbo's Avatar
essexrsturbo
Nov 5, 2015 08:12 PM
Nov 3, 2015 04:08 PM
gavt123
Sep 5, 2015 10:03 AM
hopper350
Sep 4, 2015 12:53 AM
StephTell
Sep 2, 2015 06:31 PM
