RS won't start?
Old Oct 22, 2005 | 12:47 PM
mantamark's Avatar
mantamark
Default RS won't start?
Posted on behalf of a mate...
ot a series two rs turbo, it's been stood for just over a week, tried to start it this morning - nothing, doesn't even turn over.
Changed the battery to a new one, and put a re-con starter motor on, still nothing is happening.
It's driving me mad, no problems before-hand in the last few weeks to indicate something was up, it's been starting first time, every time, until now.
It was compression tested just over a month ago, 150 across all four - about as perfect as it could be, no mixing or overheating either, and the car runs fine, apart from a blow from the exhaust manifold gasket.
Any one have any ideas?
Many thanks in advance!
Old Oct 23, 2005 | 02:21 PM
Taylor's Avatar
Taylor
Default Non starter
Is it getting ignition light's,if not then something electrical or that maybe,immobilised?
Old Oct 23, 2005 | 02:33 PM
AJC's Avatar
AJC
wiring?
strip the steering column and there are electric blocks to ignition barrel
and others etc, wiggle em or disconnect/clean and re connect
i had a similar problem not so long sice but dazC sored it for me
Old Oct 23, 2005 | 04:41 PM
mantamark's Avatar
mantamark
Cheers, it was the ecu
Old Oct 23, 2005 | 04:49 PM
Taylor's Avatar
Taylor
No probs mate
Rob Wells
Ford Mondeo Including ST
Apr 18, 2023 12:19 AM
xrmalin
Sep 13, 2015 06:52 PM
Marino
Sep 12, 2015 11:10 AM
stevierob
Sep 7, 2015 07:09 PM
kevin36
Sep 2, 2015 06:24 PM
