Fiesta turbo Managment
Old Oct 22, 2005 | 10:58 AM
S2 turbo's Avatar
S2 turbo
Default Fiesta turbo Managment
Hi peeps,
After thinking about it for a while im planning on goin to EFi managment how easy is this and what do i need to fo this
Dave
Old Oct 22, 2005 | 11:08 AM
Gotech Racing's Avatar
Gotech Racing
Default Re: Fiesta turbo Managment
Originally Posted by S2 turbo
Hi peeps,
Dave
Hi Dave
Have you looked at Gotech MFI-STD or MFI-PRO It's perfect for the Escort/Fiesta turbo.
It's available through Jamsport, and is a full engine management system.
You can drive the coil, or coil-pack directly from the ecu, so you can loose the ignition amplifier.
You gain excellent low/ mid speed power and drivability, and some top end power. If you car is modded with cams, bigger turbos ect, the gains will be much more
You also get Launch control/datalogging/closed loop lambda fuel control/nitrous and water injection control, and much more!
have a look here
https://passionford.com/forum/viewtopic.php?t=146861
As fitted to Performance Ford Magazines RS turbo, and fully tested. Have you read the report?
Old Oct 22, 2005 | 12:45 PM
Oranoco's Avatar
Oranoco
How much roughly for a drive in drive out service. Toying with the idea for my Escort early next year?
Old Oct 22, 2005 | 01:03 PM
Gotech Racing
Hi
Give Jamie at JamSport a ring - 01604 755529
They are the official dealers and fitters, and can give you an exact quote
www.jam-sport.co.uk
I think you're looking at £1000 fitted and mapped, drive away
Andrew
Old Oct 22, 2005 | 01:15 PM
S2 turbo's Avatar
S2 turbo
Cheers M8
Well im goin for a 2.1zvh with a stage 3 head and just want a good managment to run it to get the full potential of it
Cheers Dave
Old Oct 22, 2005 | 01:20 PM
Oranoco's Avatar
Oranoco
Won't call just yet as I have two projects to work on over the winter months.
Old Oct 23, 2005 | 07:04 PM
adamS2RST's Avatar
adamS2RST
Basic EFI bits needed are:
FRST EFI inlet and injectors
FRST OFAB/C engine loom and EDIS module
MAP sensor (FRST or Cos)
OFAB/C ECU
crank postion sensor
36-1 teeth pick up pulley
1.8 Sierra alternator bracket (unless you mod the alternator)
air filter (Cos T3 will fit with standard pipe)
coil pack
inlet conversion plate (unless you use EFI head)
FRST HT leads
EFI XR3i fuel filter to fuel rail pipe (to keep original ERST fuel filter)
EFi rev counter
This site may help you: www.rsbible.co.uk
HTH
Old Oct 23, 2005 | 08:59 PM
S2 turbo's Avatar
S2 turbo
Cheers adam thats great m8
Matt Baxter
Sep 16, 2015 08:30 PM
paceo
Aug 27, 2015 12:45 PM
Seanyfarrell
Aug 14, 2015 11:37 PM
turbobill
Aug 1, 2015 08:55 PM
