headlights
Old Jul 6, 2004 | 11:32 AM
damncar's Avatar
damncar
Default headlights
my dip lights are only working intermittently. full beam is ok & the parking lights but when I dip the beams from full everything goes dark!! disconcerting....
obviously it's not the bulbs, everything appears to be connected well, fuses are intact,
any ideas anyone before I start ripping the control stalk out?
Motor is an xr3i efi.
Ta for the mail Petrucci, it's great to see the site achieving such success
DC
Old Jul 6, 2004 | 11:33 AM
Ryan's Avatar
Ryan
sounds like either the relay on the back of the stalk or the stalk itself.
failing that it will be the relays in the fuse box
Old Jul 6, 2004 | 11:59 AM
damncar's Avatar
damncar
cheers Ryan I'll take a look @ those relays first
Old Jul 6, 2004 | 12:44 PM
EssexBoyRacer's Avatar
EssexBoyRacer
relays in the fuse box, two small white ones (probably burnt by now) right at the back give em a wiggle and the lights'll come on.
bastard to repair, only quick fix is to clean up the pins as best as possible and ensure as good a contact as u can.
Old Jul 10, 2004 | 10:14 AM
damncar's Avatar
damncar
iT was one of those relays ok, effin haynes manual said they were under the instrument panel so I looked there first. gave them a clean a wiggle And now I SEEETHE LIGHT!!!!
Old Jul 10, 2004 | 10:32 AM
EssexBoyRacer
Tank Mike
Ford Focus Diesel
Feb 23, 2022 06:09 PM
Nov 1, 2015 06:53 PM
Steve Escos
Oct 1, 2015 06:57 AM
mondeomark
Sep 28, 2015 06:28 AM
Kam B
Sep 24, 2015 10:40 AM
