As requested, some pictures of my Stack
With Defi EGT on left and water temp on right. Although the Stack has water temp, I prefer an analogue gauge for this, as you can see the second something isn't quite right.
www.stackltd.com - ST8130P
3-8000 and also -3-10500 ...
is this referring to the max revs ???
in other words.. is the white stack also available up to 10.000 rpm ??
(because I run with mechanical lifters I can go over 8000!)
and your idea makes a lot of sense with the egt and the watertemp!!
very bling!
Yes it is. I have the smaller round Stack jobbie and think its always worth having the 10k rpm version as you get to see just how high you revved your now broken engine when you stuck it in the wrong gear.
Mikes dash looks the nuts
Originally Posted by Porkie
Thrush, Mike got those warning lights from R&B motorsport.
My Name is Stretch and dont you forget it.
Pete / Pim,
Yes the Stack can come in a variety of rev range options. The next range step up from mine is 10,500 rpm. This is a "no extra cost" option.
Adrian,
Try and get all the correct legends from them then
Adrian,
no he got you right, as your an iratable kunt
Thrush
Don't carry in stock, they are are ordered in to suit particular car at time. Did you want just lights with no wiring, or wired up to plug staight into your original loom?
,Don't carry in stock, they are are ordered in to suit particular car at time. Did you want just lights with no wiring, or wired up to plug staight into your original loom?
Would you want legends as well? As you can see yellow, red, green and blue are the colours available.
On mine I have two yellow for ABS and washer bottle warning, three red for handbrake, battery and oil warning, green for indicators and blue for main beam.
Pete / Pim,
Then I got to have it.. PM the price please including the defi-egt and the defi watertemp also in white ?
Spiky=While your still alive.
Did spadge give you a bolt/spacer for a cambelt cover as paul didnt come down with one.
Did spadge give you a bolt/spacer for a cambelt cover as paul didnt come down with one. failing that PM spadge
Pim,
The ST8130P is £1,146 + £150 for Escort idiot lights (airbag model) / loom to just plug in, and the Defi prices are on our web site in the gauges section.
You can reduce the price of the Stack by not having the fuel pressure feature.
Pim,
FPMSL!
